Zynthian UI User's Guide - Oram
  Short Push Push and release in less than 0.3 seconds.
  Bold Push Push and hold for longer than 0.3 seconds then release before 2 seconds.
  Long Push Push and hold for longer than 2 seconds. Long-action triggers before release.
  Knob Rotate Rotate the knob.
  • a list of controller pages, grouped by processor
  • 4 x controller widgets, dynamically assigned to the parameters of the selected page. The controller widgets are layered aside the 4 rotary encoders that can be used for modifying the parameter's value in real time.Depending of configuration options, the controller widgets could be layered at the four display corners (classic layout: top-left, down-left, top-right, down-right) or they could be all at right (V5 layout).
    • short-push any knob to start MIDI-learning for the associated parameter. If wanted, a second push for global learning. Move a knob/fader in your MIDI controller to complete the learn. You can push BACK button to cancel at any moment.
    • short-push (midi learning) to cancel midi learning.
    • short-push any knob to start MIDI-learning. If wanted, a second push for global learning. Move a zynthian's knob to select the parameter. Then, move a knob/fader in your MIDI controller to complete the learn. You can push BACK button to cancel at any moment.
    • bold push to open preset options menu.
    • bold-push to open the preset options menu.
    • bold push to open bank options menu.
    • bold-push to open the bank options menu.
5.8 MIDI input/output
5.9 Key range & transpose
5.10 Snapshots
5.11 ZS3 (sub-snapshots)
5.12 Confirmation dialog
5.13 On-screen keyboard
5.14 Admin
5.15 Audio levels
6.3 Layering chains
The pattern editor has a custom ALT mode. For accessing it, simply push the ALT button and the arrow buttons will change its color to orange, allowing to quickly access undo/redo functions:
10 Learning Pills
10.1 Basics
10.2 Sequencer
10.3 Mini-HowTos
