Zynthian UI User's Guide - Oram
  Short Push Push and release in less than 0.3 seconds.
  Bold Push Push and hold for longer than 0.3 seconds then release before 2 seconds.
  Long Push Push and hold for longer than 2 seconds. Long-action triggers before release.
  Knob Rotate Rotate the knob.
  • OPT/ADMIN
    • Options / Menu: Contextual. Push several times until reach the main menu.
    • Admin menu
  • MIX/LEVEL
  • CTRL/PRESET
  • ZS3/SNAPSHOT
    • ZS3 (SubSnapShots)
  • METRONOME
    • Tempo settings / Tap-Tempo
  • PAD/STEP
    • ZynPad (Scene)
    • Pattern Editor
  • long-push OPT/ADMIN to power off.
  • long-push CTRL/PRESET to enter/leave preset favorites
  • Long-push PAD/STEP to access the arranger view
Zynsampler
Sooperlooper
  • a list of controller pages, grouped by processor
  • 4 x controller widgets, dynamically assigned to the parameters of the selected page. The controller widgets are layered aside the 4 rotary encoders that can be used for modifying the parameter's value in real time.
    • short-push any knob to start MIDI-learning for the associated parameter. If wanted, a second push for global learning. Move a knob/fader in your MIDI controller to complete the learn. You can push BACK button to cancel at any moment.
    • bold push to open preset options menu.
    • bold push to open bank options menu.
5.8 MIDI input/output
5.9 Key range & transpose
5.10 Snapshots
5.11 ZS3s (sub-snapshots)
5.12 Confirmation dialog
5.13 On-screen keyboard
5.14 Admin
6.3 Layering chains
The pattern editor has a custom ALT mode. For accessing it, simply push the ALT button and the arrow buttons will change its color to orange, allowing to quickly access undo/redo functions:
8.4 Tempo options
10 Learning Pills
10.1 Basics
10.2 Sequencer
10.3 Mini-HowTos
