Zynthian UI User's Guide - Oram
Chains receive MIDI data from a set of MIDI inputs. These MIDI inputs could be external MIDI devices (sequencers, keyboards and other MIDI controllers) or other MIDI sources (MIDI network services, etc.) and they can be configured for each chain separately. Each MIDI input can work in 2 different modes:
When an MIDI input is configured in active mode, the active chain (the highlighted/selected chain) receives all MIDI input from it and all MIDI events are translated to the active chain's MIDI channel. It's the default mode for all MIDI inputs. When using active mode you don't need to worry about the MIDI channel your keyboard/controller is using. You change which instruments are played by changing the active chain in your zynthian (see below).
  • Active MIDI channel Disabled => Only the active chain receives data from the MIDI input in active mode. It's the default.
  • Active MIDI channel Enabled => All chains with the same MIDI channel as the active chain receive data from the MIDI input in active mode. This is very useful for layering sounds without any extra routing. You simply create several synth chains with the same MIDI channel and they will play in unison. You can also create keyboard splits by adjusting note range and transpose for each chain from the chain options menu.
When a MIDI input is configured in multitimbral mode, only chains matching the input's MIDI channel will receive data from this MIDI input. No MIDI channel translation is performed. Multitimbral mode allows receiving and managing each MIDI channel individually. Each MIDI input select the chains it drive using the MIDI channel. If you are using an external sequencer or a MIDI controller that can sequence multiple tracks (Beatstep Pro, Keystep Pro, Novation Circuit, etc.), you may want to use multitimbral mode.
  • chain layout: for each chain, the processors and how they are arranged
  • chain configuration: for each chain, MIDI channel, note-range, transpose, etc.
  • patterns & sequences: sequencer contents
  • sub-snapshots (ZS3s): see ZS3
  • some config options: ENUMERATE!!
Users interact with the system by pushing the silicone buttons or knob-switches or rotating the knobs. Touch can be used too for most operations and some interactions are only available from the touch interface, like the X-Y control ala kaos pad. User actions normally produce some feedback in the display. Also, the V5's RBG LEDs give feedback and status info.
3.3 Types of push action
3.4 Using the push buttons
  • OPT/ADMIN
    • Admin menu
  • MIX/LEVEL
    • Mixer
  • CTRL/PRESET
    • Chain Control (Instrument)
    • Preset/Bank
  • ZS3/SNAPSHOT
    • SubSnapShots (ZS3s)
  • METRONOME
    • Tempo options / Tap-Tempo
  • PAD/STEP
    • Scene (ZynPad)
    • Pattern
Pattern editor view
Zynsampler control view
  • Up/Down arrow buttons:
  • Left/Right arrow buttons:
  • Select/Yes button:
  • Back/No button:
3.5 Using the knobs
Knobs & buttons
5.3 Engine selection
  • Knob#1 - #4
From the chain control view you can change the active chain using the left/right arrows.
5.5 Chain options
5.6 MIDI input/output
5.7 Banks & Presets
5.8 Snapshots
5.9 ZS3s (sub-snapshots)
5.10 Confirmation dialog
5.11 On-screen keyboard
5.12 Admin
6.3 Layering chains
8.4 Tempo options
9 Learning Pills
9.1 Basics
9.2 Sequencer
9.3 Mini-HowTos
