Building Zynthian MINI V2
Revision as of 11:13, 6 May 2024 by Jofemodo (talk | contribs)
Zynthian Mini kit is a cost effective approach to build a zynthian box with similar functionality to v5 kit.
The pros:
+ Lower price + Possibility of inserting a standard RPi-hat. + Smaller format. It's slighty higher than V5, but quite shorter. + More DIY! You will learn a lot more while building it
The cons:
+ No audio input + No amplified headphones output + No separated TRS audio connectors. No balanced output/input + No USB-B connector. Connecting to PC as USB device is more difficult, but still doable. + Overclocking could cause over-heating. The plastic/fiber-glass case can't be used as a heat-sink + No RGB LED feedback on push buttons + More difficult to assemble. It requires more time and greater skills (i.e. soldering some electronic parts on the PCB) + Not so robust. Not so cool, but ... heyyy!! MINI-V2 is also quite cool! ;-)
  • encoders and switches to control zynthian software in the same way as official zynthian v5 kit, using the MCP23017 i/o extender
  • standard DIN-5 connectors for MIDI IN, OUT and THRU
  • it uses a I2S DAC for audio out based on PMC5102 chip that is affordable to buy
  • all RPi connectors are easy to reach
Zynthian MINI is currently at version 2. Previous version 1 was more similar to official V4 kit with only 4 buttons but it is not maintained anymore.
To assemble zynthian MINI V2 version you will require:
  • Components that need to be soldered on this PCB.
  • 5" Screen
  • optional: zynthian MINI V2 3d printable case
1 Assembling the PCB
1.1 Components required
5. Diode
7. Resistors
8. Resistor
9. Resistor
10. Digital Optocoupler
12. Sound Card PCM5102
13. I/O Expander
15. Encoder with a Switch
16. Encoder Cap
17. Push Button
20. 1/4 Stereo jack
21. RCA Stereo jack
1.2 Soldering
Then solder the switches.
1.3 Assembling the PCB for the test
2 Configure Zynthian MINI V2 for testing
2.1 Connect to zynthian web UI to update zynthian software
  • selecting admin option
  • selecting your network
  • entering your wifi password
2.2 Update zynthian oram software
2.3 Configuring zynthian mini v2 as a kit
2.4 Adjusting UI for Zynthian layout
3 Assembling Zynthian MINI V2 into 3d printable enclosure
Top
Bottom
SD card door
Legs
These are small legs that are attached (glued) to the bottom part. They are designed to be a separate part from bottom part so that bottom part can be placed to printing bed and sliced without too much additional support. There is one stl file for one leg so you will need to print four of these.
You can either print this case yourself if you have a printer or give these 4 files to some of your friends that have it and point them to instructions here. Also you can request somebody to print this for you on thingiverse.
3.1 3D printing instructions
Here is a timelapse of the print.
Then print bottom part. Lay bottom side of bottom part onto the printer bed. Use the same settings as for previous parts. Bottom part will be printed much quicker.
3.2 Assembling all parts into 3D printed case
  1. Case Top part
  2. Case Bottom part
  3. Case SD Card door part
  4. Case legs parts
  5. brass heat set inserts (quantity 8) - M2.5xL4xOD3.5 - can be purchased here
  6. screws for brass heat set inserts (quanity 8) - M2.5, 6mm - can be purchased here
  7. 5" DSI screen and its screws - can be purchased here
  10. Neutrik 1/4 stereo connector cap - can be purchased [1]
3.3 Insert 3 heat set inserts into top and 5 into bottom part
3.4 Put screen inside the top part
3.5 Screw raspberry pi posts and HAT posts to the PCB
3.6 Put PCB into the case and attach the screen screws
3.7 Screw PCB to the case
3.8 Screw encoder screw nuts
3.9 Screw Neutrik connector nut
3.10 Attach screen cable to the raspberry pi
3.11 Connect raspberry pi to the PCB
3.12 Attach the sd card door to bottom pat using a screw and glue legs to bottom part
3.13 Screw bottom part to top part
