Building Zynthian MINI V2
Revision as of 09:12, 6 May 2024 by Stojos (talk | contribs)
Zynthian Mini kit is a cost effective approach to build zynthian with intention to give opportunity:
  • to zynthian developers to get functional zynthian similar to v5 where they can do most of the testing
  • to musician to get to know zynthian and learn their features before deciding to but the professional kit
  • include encoders and switches that controll zynthian software in the same way as official zynthian v5 kit using the MCP23017 i/o extender
  • include MIDI IN, MIDI OUT and MIDI THRU
  • include a I2S DAC for AUDIO OUT based on PMC5102 chip that is affordable to buy
  • all connectors are easy to reach (V1 does not have RPI connectors aligned to the edge of the PCB)
To save the cost of building the Zynthian MINI, we had to sacrifice certain features that some professional musicians would need on the stage such as:
  • no audio-in
  • no TRS audio connectors
  • not best in the class DAC for audio out
  • no rigid metal case
  • no zynaptik analog inputs
Zynthian is currently at version 2. Previous version 1 was more similar to official V4 kit with only 4 buttons but it is not maintained anymore.
To assemble zynthian mini V2 version you will require:
  • Components that need to be soldered to this PCB.
  • 5" Screen
  • optional: zynthian MINI V2 3d printable case
1 Assembling the PCB
1.1 Components required
5. Diode
7. Resistors
8. Resistor
9. Resistor
10. Digital Optocoupler
12. Sound Card PCM5102
13. I/O Expander
15. Encoder with a Switch
16. Encoder Cap
17. Push Button
20. 1/4 Stereo jack
21. RCA Stereo jack
1.2 Soldering
Then solder the switches.
1.3 Assembling the PCB for the test
2 Configure Zynthian MINI V2 for testing
2.1 Connect to zynthian web UI to update zynthian software
  • selecting admin option
  • selecting your network
  • entering your wifi password
2.2 Update zynthian oram software
2.3 Configuring zynthian mini v2 as a kit
2.4 Adjusting UI for Zynthian layout
3 Assembling Zynthian MINI V2 into 3d printable enclosure
