Supported plug & play MIDI controllers
| Device | Launcher mode (ZynPad) | Mixer mode (ZynMixer) | SuperLooper mode | Sequencer mode (ZynSeq) | Extra features / notes |
| Akai APC Key25 MK2 | yes | yes | no | yes | Mixpad (default) controls Mixer + ZynPad; also Step Sequencer / pattern editor; Device mode controls the Zynthian UI. |
| Akai APC Key25 MK2 + SL | yes | yes | yes | yes | Adds SooperLooper looper controls + Levels/Pan/Sync&Quantize/Session save+load; base modes otherwise match the non-SL driver. |
| Akai MIDI MIX | incomplete | yes | no | incomplete | Maps mixer functionality (chains 1–16 via banks, master slider, balance, mute/solo, rec-arm). |
| Akai MPK mini MK3 | yes | yes | no | yes | Modes: Mixer (default), Device UI, Pattern (ZynPad + Pattern Editor), NotePad; plus User and Config modes. |
| Akai MPK mini MK3 Moder | incomplete | incomplete | incomplete | incomplete | (Details not extracted from this page section.) |
| Novation LAUNCHPAD MINI MK1 | yes | incomplete | no | incomplete | ZynPad driver. |
| Novation LAUNCHPAD MINI MK3 | yes | incomplete | no | incomplete | ZynPad driver. |
| Novation LAUNCHPAD PRO MK2 | yes | incomplete | no | incomplete | ZynPad driver. |
| Novation LAUNCHPAD PRO MK3 | yes | incomplete | no | incomplete | ZynPad driver. |
| Novation LAUNCHPAD X | yes | incomplete | no | incomplete | ZynPad driver. |
| Novation LAUNCHKEY MINI MK3 | yes | yes | no | incomplete | Mixer + ZynPad. |
| Novation LAUNCHKEY 88 MK3 | yes | yes | no | incomplete | Mixer + ZynPad. |
| Behringer MOTÖR 61 / 49 | incomplete | incomplete | incomplete | incomplete | (Details not extracted from this page section.) |
| Korg nanoKONTROL | incomplete | yes | no | incomplete | ZynMixer driver. |
| Korg nanoKONTROL-2 | incomplete | yes | no | incomplete | ZynMixer driver. |
| Mackie Control | incomplete | incomplete | incomplete | incomplete | (Details not extracted from this page section.) |
| Fostex Mixtab | incomplete | incomplete | incomplete | incomplete | (Details not extracted from this page section.) |
| Teenage Engineering OP-1 | incomplete | incomplete | incomplete | incomplete | Configuring/usage section. |
| SooperLooper CCx10, for Behringer FCB1010 & others | incomplete | incomplete | yes | incomplete | SooperLooper CCx10 controller support. |
1 Akai APC Key25 MK2
1.1 The Mixpad mode
- Toggle audio playback with
- Toggle audio record with
- Press
- Mute main chain, pressing
SHIFT+PLAY.
- Use
- Open the ZynPad pressing
SHIFT+DOWN arrow.
1.2 The Device mode
1.3 The Step Sequencer mode
- Press and hold
- Buttons
- Press
- Pressing
- Press
1.3.4 Pattern Manager Mode
- Clear a pattern, pressing
2 Akai APC Key25 MK2 + SL
Volume:
Pan:
Opens/closes the Pan mode
Send:
Device:
2.1 Looper mode
The commands are:
Rec/Overdub (red/purple)
Multiply (amber)
Insert (warm pink)
Replace (pink light
Substitute (pink)
Oneshot (light green)
Trigger (green)
Pause (lime).
2.1.1 Groups
2.1.2 Soft keys
2.1.3 Track buttons
Shift + ▲ and Shift + ▼:
◀ and ▶:
2.1.4 Knobs
2.6 Pan mode
2.7 Sync/Quantize mode
3 Akai MIDI MIX
3.1 ZynMixer driver
- Master Slider: Main volume
- Lower Knob: Chain's balance
- Mute: Chain's mute switch
- Solo: Push
- Slider: Chain's volume
4 Akai MPK mini MK3
4.1 The Mixer mode
4.2 The Device mode
- In bank A:
- Use
- Use
- In bank B:
4.3 The Pattern mode
PAD 3as SHIFT, when required.
- Step's duration:
K8. - Step's stutter count:
- Step's duration:
In Zynpad, you may:
4.4 The NotePad mode
4.5 The User mode
4.6 The Config mode
5 Akai MPK mini MK3 Moder
| Pad | Mode |
| Pad 1 | Chromatic |
| Pad 2 | Major |
| Pad 3 | Minor |
| Pad 4 | Harmonic Minor |
| Pad 5 | Melodic Minor |
| Pad 6 | Dorian |
| Pad 7 | Mixolydian |
| Pad 8 | Lydian |
| Pad 1 | Chromatic |
| Pad 2 | Phrygian |
| Pad 3 | Locrian |
| Pad 4 | Super Locrian |
| Pad 5 | Bhairav |
| Pad 6 | Hungarian Minor |
| Pad 7 | Minor Gypsy |
| Pad 1 | Chromatic |
| Pad 2 | Minor Pentatonic |
| Pad 3 | Major Pentatonic |
| Pad 4 | Hirojoshi |
| Pad 5 | In-Sen |
| Pad 6 | Iwato |
| Pad 7 | Kumoi |
| Pad 8 | NONE |
| Pad 1 | Chromatic |
| Pad 2 | Diminished |
| Pad 3 | Whole-Half |
| Pad 4 | Spanish |
| Pad 5 | Whole Tone |
| Pad 6 | Minor Blues |
| Pad 7 | Pelog |
| Pad 8 | NONE |
6 Novation LAUNCHPAD MINI MK1
6.1 ZynPad driver
7 Novation LAUNCHPAD MINI MK3
7.1 ZynPad driver
8 Novation LAUNCHPAD PRO MK2
8.1 ZynPad driver
9 Novation LAUNCHPAD PRO MK3
9.1 ZynPad driver
10 Novation LAUNCHPAD X
10.1 ZynPad driver
11.1 Mixer & ZynPad driver
12 Novation LAUNCHKEY 88 MK3
12.1 Mixer & ZynPad driver
13 Behringer MOTÖR 61 / 49
This driver is focused in stage control of setBfree and Pianoteq engines. It also includes the mode enforcer that can be controlled from the pads (notes). This driver must be loaded in the device's MIDI port 1. Please, note that you can also load, simultaneously if needed, the generic Mackie driver in the MIDI port 2.
14 Korg nanoKONTROL
14.1 ZynMixer driver
Not supported yet!
15 Korg nanoKONTROL-2
15.1 ZynMixer driver
15.1.1 Common buttons
- Track Left: UI Left arrow
- Track Right: UI RIGHT arrow
- Marker Left: UI UP arrow
- Marker Right: UI DOWN arrow
15.1.2 NORMAL mode
- Knob: Chain's balance
- M: Chain's mute switch
- S: Chain's solo switch
15.1.3 SHIFT mode
- Strip 8: Main mixer control
- Slider: Main volume
- M: Main mute switch
- R: Main recorder arm switch
16 Mackie Control
- Original MCU hardware
- Behringer X-Touch
- Behringer BCF2000
- Zoom R8
- Etc.
17 Fostex Mixtab
- AUX
- EQ HI
- EQ LO
- PAN
- MUTE
- FADER
18 Teenage Engineering OP-1
18.1 Configuring the OP-1
- Press Shift + COM Button
- Select CTRL Mode (Press Button T2)
- Additional steps for the first time:
- Select OP-1 Mode (Press Button T1)
18.2 Usage
- Tempo
- Play/record toggle
- Arrows up-down, left-right
19 SooperLooper CCx10, for Behringer FCB1010 & others
| Pedal | CC | What it does |
| 1 | 15 | Mute current loop (stop recording if needed) → advance to next loop → arm it for recording |
| 2 | 16 | Solo-trigger loop 2: mute loops 3–5, trigger loop 2 |
| 3 | 17 | Solo-trigger loop 3: mute loops 2, 4, 5, trigger loop 3 |
| 4 | 18 | Solo-trigger loop 4: mute loops 2, 3, 5, trigger loop 4 |
| 5 | 19 | Solo-trigger loop 5: mute loops 2, 3, 4, trigger loop 5 |
| 6 | 20 | Advance to the next loop (selection only — nothing is muted or triggered) |
| 7 | 21 | Mute the currently selected loop |
| 8 | 22 | Start/stop recording on the currently selected loop |
| 9 | 23 | Soft reset: stop all recording, mute everything, reselect loop 1, re-sync. Recorded audio is kept. |
| 10 | 24 | Start/stop recording — mapped directly in Zynthian to Record Loop 1 (not managed through the ctrldev driver) |
This drivers has been originally designed for the Behringer FCB1010, but it can be used with any MIDI controller sending the right MIDI CC as described in the table below.
Each pedal of the FCB1010 is mapped to CC and SooperLooper as described in the next table. Note that you MUST configure your FCB1010 to send triggers with the specified CC numbers. It won't work with FCB's factory assignments, as they are "frankly daft". Of course, you could configure any other MIDI controller to send the same CC numbers and use it instead, so to some extend, this driver is not exclusive for the FCB1010, although it's been designed with it in mind.
This driver implements a specific, but quite common yet, workflow specially tailored to play Jazz Standards, although it probably suits other genres too. It works like this:
- Loop 1 is always treated as the timing reference — everything else quantizes to it. I tap in a rhythm, usually with conga drums on my keyboard’s drum pads. I then let that rhythm play out while setting the quantize loop for all remaining loops.
- I then use Pedal 1 to record verse and chorus sections as separate loops. Each loop is quantized, so I just need to remember to hit “Pedal 1” near the end of the verse to tell SooperLooper to begin recording the next loop. For example, when I’m ready to record the verse, I hit pedal 1 and SooperLooper begins recording Loop 2 on the next beat. When I’m ready to do the chorus, I hit pedal 1 again. SooperLooper finishes recording Loop 2, mutes Loop 2, then begins recording Loop 3 on the next beat, and so on.
- Sometimes, I will record a verse and then end the recording by hitting Pedal 8, causing that loop to continue playing from the beginning. This allows me to repeat the verse and then only start recording the next loop when I need to play the second ending that goes to the chorus (this is a very common jazz pattern).
- Once I have recorded my loops, I then click one of the “solo” pedals to begin soloing over the chord changes. In most jazz standards, I go back to the first verse which is on Loop 2, so I click “Pedal 2”. I then click the remaining pedals to go through the rest of the song structure. By triggering each loop, I can have sections of different lengths (again, another thing you’ll commonly find in jazz standards). Everything is quantized to the rhythm track, so moving from loop to loop is all seamless.
The upshot is that this driver allows me to lay down my backing bass and chord track at the beginning of the song, then play this throughout while doing the melody and solos. I think it will work for just about any jazz standard without having to adjust the default 43 second loop length, since four loops (loops 2-5) covers a lot. I can do all of this in real time because each action is done by just one pedal. It’s intuitive because I just hit the pedal assigned to the verse or chorus I want to play and it triggers from the start exactly on the quantized beat.
19.1 Configure the Behringer FCB1010
Here’s how to configure the FCB1010, assuming starting from FCB1010’s factory default:
* Select the pedal you want to program (e.g., 1). * Long press the Down button (2-3 seconds) to put the pedal in programming mode. * Short press the Up button. * By default, “1” is lit, indicating that the pedal is sending a program change. We need it to send a control change (“6”). * Long press “1” (program change) until it is unlit. * Long press “6” (control change) until it is lit. * Short press “6” to program the control change. “6” will start blinking. * Press Up. * Enter the CC number you want to set for the pedal. For example, in this ctrldev, I map Pedal 1 to CC 15. Numbers are entered by clicking the pedal numbers in order (e.g., “1” and “5”). The numbers will appear in the LED screen. * Press Up. * Enter the value you want to send for the CC. I enter “127” for every control (e.g., “1”, “2”, “7”). * Press Up. “6” stops blinking and is solidly lit. The pedal is now programmed. * Long press Down to exit programming mode. * Repeat 1-13 for each pedal (e.g., Pedal 2 = CC 16, etc.).
I’ve uploaded a demo song (“Night and Day”) that I recorded using my Zynthian setup with this ctrldev driver:
It was recorded live. I hit the record button on the Zynthian to start and stop the recording. Nothing in there was layered on tracks.
Here’s how I progressed through the song structure with the pedals on the FCB1010:
10: start recording bongos 10: stop recording bongos 1: start verse 1 8: repeat verse 1 (first ending) 1: stop verse 1, start second ending of verse 1 into chorus 2: start verse 1 3: start 2nd ending and chorus 2-3: continue going back and forth between these for the whole song structure. 1: record a coda as a new track at the end 8: repeat coda so I can solo over it. 9: end song
This will be a real game changer for me to be able to do solo gigs as well as playing with just one other instrument or vocalist. Hopefully this is helpful to others.
20 Technical Info For Driver Developers
# Control device base class
def __init__(self):
def setup(self, idev=None):
if idev != self.idev:
self.release()
# Init new selected device
if idev > 0:
self.idev = idev
# Setup routing
self.init()
self.refresh(force=True)
def release(self):
if self.idev > 0:
self.end()
# Restore routing
self.idev = 0
# Device MIDI event handler
def midi_event(self, ev):
# Light-Off LEDs
def light_off(self):
# Sleep On
def sleep_on(self):
self.light_off()
# Sleep On
def sleep_off(self):
self.refresh(True)
