Supported plug & play MIDI controllers
1 Akai APC Key25 MK2
1.1 The Mixpad mode
- Toggle audio playback with
- Toggle audio record with
- Press
- Mute main chain, pressing
SHIFT+PLAY.
- Use
- Open the ZynPad pressing
SHIFT+DOWN arrow.
1.2 The Device mode
1.3 The Step Sequencer mode
- Press and hold
- Buttons
- Press
- Pressing
- Press
1.3.4 Pattern Manager Mode
- Clear a pattern, pressing
2 Akai APC Key25 MK2 + SL
Volume:
Pan:
Opens/closes the Pan mode
Send:
Device:
2.1 Looper mode
The commands are:
Rec/Overdub (red/purple)
Multiply (amber)
Insert (warm pink)
Replace (pink light
Substitute (pink)
Oneshot (light green)
Trigger (green)
Pause (lime).
2.1.1 Groups
2.1.2 Soft keys
2.1.3 Track buttons
Shift + ▲ and Shift + ▼:
◀ and ▶:
2.1.4 Knobs
2.6 Pan mode
2.7 Sync/Quantize mode
3 Akai MIDI MIX
3.1 ZynMixer driver
- Master Slider: Main volume
- Lower Knob: Chain's balance
- Mute: Chain's mute switch
- Solo: Push
- Slider: Chain's volume
4 Akai MPK mini MK3
4.1 The Mixer mode
4.2 The Device mode
- In bank A:
- Use
- Use
- In bank B:
4.3 The Pattern mode
PAD 3as SHIFT, when required.
- Step's duration:
K8. - Step's stutter count:
- Step's duration:
In Zynpad, you may:
4.4 The NotePad mode
4.5 The User mode
4.6 The Config mode
5 Akai MPK mini MK3 Moder
| Pad | Mode |
| Pad 1 | Chromatic |
| Pad 2 | Major |
| Pad 3 | Minor |
| Pad 4 | Harmonic Minor |
| Pad 5 | Melodic Minor |
| Pad 6 | Dorian |
| Pad 7 | Mixolydian |
| Pad 8 | Lydian |
| Pad 1 | Chromatic |
| Pad 2 | Phrygian |
| Pad 3 | Locrian |
| Pad 4 | Super Locrian |
| Pad 5 | Bhairav |
| Pad 6 | Hungarian Minor |
| Pad 7 | Minor Gypsy |
| Pad 1 | Chromatic |
| Pad 2 | Minor Pentatonic |
| Pad 3 | Major Pentatonic |
| Pad 4 | Hirojoshi |
| Pad 5 | In-Sen |
| Pad 6 | Iwato |
| Pad 7 | Kumoi |
| Pad 8 | NONE |
| Pad 1 | Chromatic |
| Pad 2 | Diminished |
| Pad 3 | Whole-Half |
| Pad 4 | Spanish |
| Pad 5 | Whole Tone |
| Pad 6 | Minor Blues |
| Pad 7 | Pelog |
| Pad 8 | NONE |
6 Novation LAUNCHPAD MINI MK1
6.1 ZynPad driver
7 Novation LAUNCHPAD MINI MK3
7.1 ZynPad driver
8 Novation LAUNCHPAD PRO MK2
8.1 ZynPad driver
9 Novation LAUNCHPAD PRO MK3
9.1 ZynPad driver
10 Novation LAUNCHPAD X
10.1 ZynPad driver
11.1 ZynPad driver
12 Behringer MOTÖR 61 / 49
13 Korg nanoKONTROL
13.1 ZynMixer driver
Not supported yet!
14 Korg nanoKONTROL-2
14.1 ZynMixer driver
14.1.1 Common buttons
- Track Left: UI Left arrow
- Track Right: UI RIGHT arrow
- Marker Left: UI UP arrow
- Marker Right: UI DOWN arrow
14.1.2 NORMAL mode
- Knob: Chain's balance
- M: Chain's mute switch
- S: Chain's solo switch
14.1.3 SHIFT mode
- Strip 8: Main mixer control
- Slider: Main volume
- M: Main mute switch
- R: Main recorder arm switch
15 Mackie Control
- Original MCU hardware
- Behringer X-Touch
- Behringer BCF2000
- Zoom R8
- Etc.
16 Fostex Mixtab
- AUX
- EQ HI
- EQ LO
- PAN
- MUTE
- FADER
17 Teenage Engineering OP-1
Available in vangelis.
17.1 Configuring the OP-1
- Press Shift + COM Button
- Select CTRL Mode (Press Button T2)
- Additional steps for the first time:
- Select OP-1 Mode (Press Button T1)
17.2 Usage
- Tempo
- Play/record toggle
- Arrows up-down, left-right
# Control device base class
def __init__(self):
def setup(self, idev=None):
if idev != self.idev:
self.release()
# Init new selected device
if idev > 0:
self.idev = idev
# Setup routing
self.init()
self.refresh(force=True)
def release(self):
if self.idev > 0:
self.end()
# Restore routing
self.idev = 0
# Device MIDI event handler
def midi_event(self, ev):
# Light-Off LEDs
def light_off(self):
# Sleep On
def sleep_on(self):
self.light_off()
# Sleep On
def sleep_off(self):
self.refresh(True)
