Supported plug & play MIDI controllers
1 Akai APC Key25 MK2
1.1 The Mixpad mode
1.2 The Device mode
1.3 The Step Sequencer mode
    • K1: note duration
    • K2: note velocity
    • K3: stutter count
    • K4: stutter duration
1 25 / 12 2 / 1 2 / 1
2 50 / 38 4 / 3 4 / 3
3 76 / 63 8 / 6 8 / 6
4 101 / 88 12 / 10 20 / 10
5 127 / 114 20 / 15 40 / 30
1.3.4 Pattern Manager Mode
2 Akai APC Key25 MK2 + SL
Volume:
Pan:
Opens/closes the Pan mode
Send:
Device:
2.1 Looper mode
The commands are:
Rec/Overdub (red/purple)
Multiply (amber)
Insert (warm pink)
Replace (pink light
Substitute (pink)
Oneshot (light green)
Trigger (green)
Pause (lime).
2.1.1 Groups
2.1.2 Soft keys
2.1.3 Track buttons
shifting the loops
Shift + and Shift + :
and :
plus the 'global record' on the top left this way acts as a nice shortcut to clear all loops.
2.1.4 Knobs
2.6 Pan mode
2.7 Sync/Quantize mode
3 Akai MIDI MIX
3.1 ZynMixer driver
  • Master Slider: Main volume
    • Lower Knob: Chain's balance
    • Mute: Chain's mute switch
    • Slider: Chain's volume
4 Akai MPK mini MK3
4.1 The Mixer mode
4.2 The Device mode
  • In bank A:
  • In bank B:
      • PAD 6: toggle audio record.
      • PAD 7: stop audio.
4.3 The Pattern mode
    • Step's velocity: K8.
In Zynpad, you may:
4.4 The NotePad mode
4.5 The User mode
4.6 The Config mode
5 Akai MPK mini MK3 Moder
With this driver you can choose the mode by pressing the pads and the keyboard keys will be configured so you never play a "bad" note. Nothing more.
"Program change" pads are not used by the driver, so you can still use it for ZS3 or whatever you like.
Pad Mode
Pad 1 Chromatic
Pad 2 Major
Pad 3 Minor
Pad 4 Harmonic Minor
Pad 5 Melodic Minor
Pad 6 Dorian
Pad 7 Mixolydian
Pad 8 Lydian
Pad 1 Chromatic
Pad 2 Phrygian
Pad 3 Locrian
Pad 4 Super Locrian
Pad 5 Bhairav
Pad 6 Hungarian Minor
Pad 7 Minor Gypsy
Pad 8 Spanish (8 notes!)
Pad 1 Chromatic
Pad 2 Minor Pentatonic
Pad 3 Major Pentatonic
Pad 4 Hirojoshi
Pad 5 In-Sen
Pad 6 Iwato
Pad 7 Kumoi
Pad 8 NONE
Pad 1 Chromatic
Pad 2 Diminished
Pad 3 Whole-Half
Pad 4 Spanish
Pad 5 Whole Tone
Pad 6 Minor Blues
Pad 7 Pelog
Pad 8 NONE
6 Novation LAUNCHPAD MINI MK1
6.1 ZynPad driver
7 Novation LAUNCHPAD MINI MK3
7.1 ZynPad driver
8 Novation LAUNCHPAD PRO MK2
8.1 ZynPad driver
9 Novation LAUNCHPAD PRO MK3
9.1 ZynPad driver
10 Novation LAUNCHPAD X
10.1 ZynPad driver
11.1 ZynPad driver
12 Behringer MOTÖR 61 / 49
Control Engine Parameter
Fader 1 setBfree Upper DB 16
Fader 3 setBfree Upper DB 8
Fader 4 setBfree Upper DB 4
Fader 6 setBfree Upper DB 2
Fader 1 setBfree Lower DB 16
Fader 3 setBfree Lower DB 8
Fader 4 setBfree Lower DB 4
Fader 6 setBfree Lower DB 2
Fader 1 setBfree Pedal DB 16
Fader 3 setBfree Pedal DB 8
Fader 4 setBfree Pedal DB 4
Fader 6 setBfree Pedal DB 2
Encoder 4 setBfree Reverb
Encoder 5 Pianoteq Volume
Encoder 6 Pianoteq Dynamics
Encoder 7 Pianoteq Reverb Mix
Encoders Bank 9-16 setBfree
Encoders Bank 17-24 setBfree
Pad 1 Mode Enforcer Chromatic
Pad 2 Mode Enforcer Major
Pad 3 Mode Enforcer Minor
Pad 6 Mode Enforcer Dorian
Pad 8 Mode Enforcer Lydian
Pad 2 Mode Enforcer Phrygian
Pad 3 Mode Enforcer Locrian
Pad 5 Mode Enforcer Bhairav
Pad 4 Mode Enforcer Hirojoshi
Pad 5 Mode Enforcer In-Sen
Pad 6 Mode Enforcer Iwato
Pad 7 Mode Enforcer Kumoi
Pad 8 Mode Enforcer NONE
Pad 4 Mode Enforcer Spanish
Pad 7 Mode Enforcer Pelog
13 Korg nanoKONTROL
13.1 ZynMixer driver
Not supported yet!
14 Korg nanoKONTROL-2
14.1 ZynMixer driver
14.1.1 Common buttons
  • Track Left: UI Left arrow
  • Track Right: UI RIGHT arrow
  • Marker Left: UI UP arrow
  • Marker Right: UI DOWN arrow
14.1.2 NORMAL mode
    • Knob: Chain's balance
    • M: Chain's mute switch
    • S: Chain's solo switch
14.1.3 SHIFT mode
  • Strip 8: Main mixer control
    • Slider: Main volume
    • M: Main mute switch
    • R: Main recorder arm switch
15 Mackie Control
  • Original MCU hardware
  • Behringer X-Touch
  • Behringer BCF2000
  • Zoom R8
  • Etc.
16 Fostex Mixtab
  • AUX
  • EQ HI
  • EQ LO
  • PAN
  • MUTE
  • FADER
17 Teenage Engineering OP-1
Available in vangelis.
17.1 Configuring the OP-1
  • On OP-1, press Shift + COM Button
  • Choose CTRL (Button T2)
17.2 Usage
  • Tempo
  • Play/record toggle
  • Arrows up-down, left-right
# Control device base class
	def __init__(self):
	def setup(self, idev=None):
		if idev != self.idev:
			self.release()
			# Init new selected device
			if idev > 0:
				self.idev = idev
				# Setup routing
				self.init()
				self.refresh(force=True)
	def release(self):
		if self.idev > 0:
				self.end()
			# Restore routing
		self.idev = 0
	# Device MIDI event handler
	def midi_event(self, ev):
	# Light-Off LEDs
	def light_off(self):
	# Sleep On
	def sleep_on(self):
		self.light_off()
	# Sleep On
	def sleep_off(self):
		self.refresh(True)
	def __init__(self):
		super().__init__()
			self.refresh_pads(force)
			self.refresh_zynpad_bank()
		if force:
		pass
		if force:
			self.light_off()
			if changed_state or force:
		pass
