Supported plug & play MIDI controllers
1 Akai APC Key25 MK2
1.1 The Mixpad mode
- Toggle audio playback with
- Toggle audio record with
- Press
- Mute main chain, pressing
SHIFT+PLAY.
- Use
- Open the ZynPad pressing
SHIFT+DOWN arrow.
1.2 The Device mode
1.3 The Step Sequencer mode
- Press and hold
- Buttons
- Press
- Pressing
- Press
1.3.4 Pattern Manager Mode
- Clear a pattern, pressing
2 Akai APC Key25 MK2 + SL
Volume:
Pan:
Opens/closes the Pan mode
Send:
Device:
2.1 Looper mode
The commands are:
Rec/Overdub (red/purple)
Multiply (amber)
Insert (warm pink)
Replace (pink light
Substitute (pink)
Oneshot (light green)
Trigger (green)
Pause (lime).
2.1.1 Groups
2.1.2 Soft keys
2.1.3 Track buttons
Shift + ▲ and Shift + ▼:
◀ and ▶:
2.1.4 Knobs
2.6 Pan mode
2.7 Sync/Quantize mode
3 Akai MIDI MIX
3.1 ZynMixer driver
- Master Slider: Main volume
- Lower Knob: Chain's balance
- Mute: Chain's mute switch
- Solo: Push
- Slider: Chain's volume
4 Akai MPK mini MK3
4.1 The Mixer mode
4.2 The Device mode
- In bank A:
- Use
- Use
- In bank B:
4.3 The Pattern mode
PAD 3as SHIFT, when required.
- Step's duration:
K8. - Step's stutter count:
- Step's duration:
In Zynpad, you may:
4.4 The NotePad mode
4.5 The User mode
4.6 The Config mode
5 Novation LAUNCHPAD MINI MK1
5.1 ZynPad driver
6 Novation LAUNCHPAD MINI MK3
6.1 ZynPad driver
7 Novation LAUNCHPAD PRO MK2
7.1 ZynPad driver
8 Novation LAUNCHPAD PRO MK3
8.1 ZynPad driver
9 Novation LAUNCHPAD X
9.1 ZynPad driver
10.1 ZynPad driver
11 Behringer MOTÖR 61 / 49
12 Korg nanoKONTROL
12.1 ZynMixer driver
Not supported yet!
13 Korg nanoKONTROL-2
13.1 ZynMixer driver
13.1.1 Common buttons
- Track Left: UI Left arrow
- Track Right: UI RIGHT arrow
- Marker Left: UI UP arrow
- Marker Right: UI DOWN arrow
13.1.2 NORMAL mode
- Knob: Chain's balance
- M: Chain's mute switch
- S: Chain's solo switch
13.1.3 SHIFT mode
- Strip 8: Main mixer control
- Slider: Main volume
- M: Main mute switch
- R: Main recorder arm switch
14 Mackie Control
- Original MCU hardware
- Behringer X-Touch
- Behringer BCF2000
- Zoom R8
- Etc.
15 Fostex Mixtab
- AUX
- EQ HI
- EQ LO
- PAN
- MUTE
- FADER
16 Teenage Engineering OP-1
Available in vangelis.
Designed to work with OP-1 in MIDI Mode:
- On OP-1, press Shift + COM Button
- Choose CTRL (Button T2)
16.1 Usage
- Encoder rotation (left to right is 1 to 4) - Encoder button push (and release, so short/bold/long works as expected) - Tempo - Play/record toggle - Arrows up-down, left-right
17 Technical Info For Driver Developers
# Control device base class
def __init__(self):
def setup(self, idev=None):
if idev != self.idev:
self.release()
# Init new selected device
if idev > 0:
self.idev = idev
# Setup routing
self.init()
self.refresh(force=True)
def release(self):
if self.idev > 0:
self.end()
# Restore routing
self.idev = 0
# Device MIDI event handler
def midi_event(self, ev):
# Light-Off LEDs
def light_off(self):
# Sleep On
def sleep_on(self):
self.light_off()
# Sleep On
def sleep_off(self):
self.refresh(True)
