Supported plug & play MIDI controllers
1 Akai APC Key25 MK2
1.1 The Mixpad mode
- Toggle audio playback with
- Toggle audio record with
- Press
- Mute main chain, pressing
SHIFT+PLAY.
- Use
- Open the ZynPad pressing
SHIFT+DOWN arrow.
1.2 The Device mode
1.3 The Step Sequencer mode
- Press and hold
- Buttons
- Press
- Pressing
- Press
1.3.4 Pattern Manager Mode
- Clear a pattern, pressing
2 Akai APC Key25 MK2 + SL
Volume:
Pan:
Opens/closes the Pan mode
Send:
Device:
2.1 Looper mode
The commands are:
Rec/Overdub (red/purple)
Multiply (amber)
Insert (warm pink)
Replace (pink light
Substitute (pink)
Oneshot (light green)
Trigger (green)
Pause (lime).
2.1.1 Groups
2.1.2 Soft keys
2.1.3 Track buttons
Shift + ▲ and Shift + ▼:
◀ and ▶:
2.1.4 Knobs
2.6 Pan mode
2.7 Sync/Quantize mode
3 Akai MIDI MIX
3.1 ZynMixer driver
- Master Slider: Main volume
- Lower Knob: Chain's balance
- Mute: Chain's mute switch
- Solo: Push
- Slider: Chain's volume
4 Akai MPK mini MK3
4.1 The Mixer mode
4.2 The Device mode
- In bank A:
- Use
- Use
- In bank B:
4.3 The Pattern mode
PAD 3as SHIFT, when required.
- Step's duration:
K8. - Step's stutter count:
- Step's duration:
In Zynpad, you may:
4.4 The NotePad mode
4.5 The User mode
4.6 The Config mode
5 Novation LAUNCHPAD MINI MK1
5.1 ZynPad driver
6 Novation LAUNCHPAD MINI MK3
6.1 ZynPad driver
7 Novation LAUNCHPAD PRO MK2
7.1 ZynPad driver
8 Novation LAUNCHPAD PRO MK3
8.1 ZynPad driver
9 Novation LAUNCHPAD X
9.1 ZynPad driver
10.1 ZynPad driver
11 Behringer MOTÖR 61 / 49
This is a resume of how keyboard controllers are used:
| Faders Bank 1-8 | setBfree | Upper Drawbars |
| Fader 1 | setBfree | Upper DB 16 |
| Fader 2 | setBfree | Upper DB 5 1/3 |
| Fader 3 | setBfree | Upper DB 8 |
| Fader 4 | setBfree | Upper DB 4 |
| Fader 5 | setBfree | Upper DB 2 2/3 |
| Fader 6 | setBfree | Upper DB 2 |
| Fader 7 | setBfree | Upper DB 1 3/5 |
| Fader 8 | setBfree | Upper DB 1 1/3 |
| Faders Bank 9-16 | setBfree | Lower Drawbars |
| Fader 1 | setBfree | Lower DB 16 |
| Fader 2 | setBfree | Lower DB 5 1/3 |
| Fader 3 | setBfree | Lower DB 8 |
| Fader 4 | setBfree | Lower DB 4 |
| Fader 5 | setBfree | Lower DB 2 2/3 |
| Fader 6 | setBfree | Lower DB 2 |
| Fader 7 | setBfree | Lower DB 1 3/5 |
| Fader 8 | setBfree | Lower DB 1 1/3 |
| Faders Bank 17-24 | setBfree | Pedal Drawbars |
| Fader 1 | setBfree | Pedal DB 16 |
| Fader 2 | setBfree | Pedal DB 5 1/3 |
| Fader 3 | setBfree | Pedal DB 8 |
| Fader 4 | setBfree | Pedal DB 4 |
| Fader 5 | setBfree | Pedal DB 2 2/3 |
| Fader 6 | setBfree | Pedal DB 2 |
| Fader 7 | setBfree | Pedal DB 1 3/5 |
| Fader 8 | setBfree | Pedal DB 1 1/3 |
| Encoders Bank 1-8 | setBfree & Pianoteq | |
| Encoder 1 | setBfree | Upper Drawbar 1 (highest pitch) |
| Encoder 2 | setBfree | Percussion on/off |
| Encoder 3 | setBfree | Vibrato routing |
| Encoder 4 | setBfree | Reverb |
| Encoder 5 | Pianoteq | Volume |
| Encoder 6 | Pianoteq | Dynamics |
| Encoder 7 | Pianoteq | Reverb Mix |
| Encoder 8 | Pianoteq | Reverb Duration |
| Encoders Bank 9-16 | setBfree | |
| Encoder 1 | setBfree | Lower Drawbar 1 (highest pitch) |
| Encoders Bank 17-24 | setBfree | |
| Encoder 1 | setBfree | Pedal Drawbar 1 (highest pitch) |
| Pads Bank 1-8 | Mode Enforcer | 7-note modes (white keys) |
| Pad 1 | Mode Enforcer | Chromatic |
| Pad 2 | Mode Enforcer | Major |
| Pad 3 | Mode Enforcer | Minor |
| Pad 4 | Mode Enforcer | Harmonic Minor |
| Pad 5 | Mode Enforcer | Melodic Minor |
| Pad 6 | Mode Enforcer | Dorian |
| Pad 7 | Mode Enforcer | Mixolydian |
| Pad 8 | Mode Enforcer | Lydian |
| Pads Bank 9-16 | Mode Enforcer | 7-note modes (white keys) |
| Pad 2 | Mode Enforcer | Phrygian |
| Pad 3 | Mode Enforcer | Locrian |
| Pad 4 | Mode Enforcer | Super Locrian |
| Pad 5 | Mode Enforcer | Bhairav |
| Pad 6 | Mode Enforcer | Hungarian Minor |
| Pad 7 | Mode Enforcer | Minor Gypsy |
| Pad 8 | Mode Enforcer | Spanish (8 notes!) |
| Pads Bank 17-24 | Mode Enforcer | 5-note modes (black keys) |
| Pad 2 | Mode Enforcer | Minor Pentatonic |
| Pad 3 | Mode Enforcer | Major Pentatonic |
| Pad 4 | Mode Enforcer | Hirojoshi |
| Pad 5 | Mode Enforcer | In-Sen |
| Pad 6 | Mode Enforcer | Iwato |
| Pad 7 | Mode Enforcer | Kumoi |
| Pad 8 | Mode Enforcer | NONE |
| Pads Bank 25-32 | Mode Enforcer | Other modes (custom keys) |
| Pad 2 | Mode Enforcer | Diminished |
| Pad 3 | Mode Enforcer | Whole-Half |
| Pad 4 | Mode Enforcer | Spanish |
| Pad 5 | Mode Enforcer | Whole Tone |
| Pad 6 | Mode Enforcer | Minor Blues |
| Pad 7 | Mode Enforcer | Pelog |
12 Korg nanoKONTROL
12.1 ZynMixer driver
Not supported yet!
13 Korg nanoKONTROL-2
13.1 ZynMixer driver
13.1.1 Common buttons
- Track Left: UI Left arrow
- Track Right: UI RIGHT arrow
- Marker Left: UI UP arrow
- Marker Right: UI DOWN arrow
13.1.2 NORMAL mode
- Knob: Chain's balance
- M: Chain's mute switch
- S: Chain's solo switch
13.1.3 SHIFT mode
- Strip 8: Main mixer control
- Slider: Main volume
- M: Main mute switch
- R: Main recorder arm switch
14 Mackie Control
- Original MCU hardware
- Behringer X-Touch
- Behringer BCF2000
- Etc.
You can configure the mapped actions via YAML config file.
15 Fostex Mixtab
- AUX
- EQ HI
- EQ LO
- PAN
- MUTE
- FADER
# Control device base class
def __init__(self):
def setup(self, idev=None):
if idev != self.idev:
self.release()
# Init new selected device
if idev > 0:
self.idev = idev
# Setup routing
self.init()
self.refresh(force=True)
def release(self):
if self.idev > 0:
self.end()
# Restore routing
self.idev = 0
# Device MIDI event handler
def midi_event(self, ev):
# Light-Off LEDs
def light_off(self):
# Sleep On
def sleep_on(self):
self.light_off()
# Sleep On
def sleep_off(self):
self.refresh(True)
