Supported plug & play MIDI controllers
This documentation is valid for the "oram" development branch. It's only partially valid for the current testing branch so you could find some differences.
1 Akai APC Key25 MK2
1.1 The Mixpad mode
  • Open the StepSeq mode for a given sequence, pressing SHIFT + a pad button.
  • Clear a sequence, pressing any track button + the sequence pad.
  • Start recording a pattern. For this, press RECORD + a pad button, which will 1) select the chain associated with the group of the sequence, 2) open the pattern editor for that sequence, 3) start playing the sequence and 4) start recording that sequence. If you press the pad again (without holding any other button), the recording will stop. Press again to stop playback too. You can also control the playback/recording with PLAY/PAUSE and RECORD buttons.
1.2 The Device mode
1.3 The Step Sequencer mode
    • K1: note duration
    • K2: note velocity
    • K3: stutter count
    • K4: stutter duration
1 25 / 12 2 / 1 2 / 1
2 50 / 38 4 / 3 4 / 3
3 76 / 63 8 / 6 8 / 6
4 101 / 88 12 / 10 20 / 10
5 127 / 114 20 / 15 40 / 30
2 Akai MIDI MIX
2.1 ZynMixer driver
  • Master Slider: Main volume
    • Lower Knob: Chain's balance
    • Mute: Chain's mute switch
    • Slider: Chain's volume
3 Akai MPK mini MK3
3.1 The Mixer mode
3.2 The Device mode
  • In bank A:
  • In bank B:
      • PAD 6: toggle audio record.
      • PAD 7: stop audio.
3.3 The Pattern mode
    • Step's velocity: K8.
In Zynpad, you may:
3.4 The NotePad mode
3.5 The User mode
3.6 The Config mode
4 Novation LAUNCHPAD MINI MK1
4.1 ZynPad driver
5 Novation LAUNCHPAD MINI MK3
5.1 ZynPad driver
6 Novation LAUNCHPAD PRO MK2
6.1 ZynPad driver
7 Novation LAUNCHPAD PRO MK3
7.1 ZynPad driver
8 Novation LAUNCHPAD X
8.1 ZynPad driver
9 Novation LAUNCHKEY MINI MK3
9.1 ZynPad driver
10 Behringer MOTÖR 61 / 49
10.1 ZynPad driver
10.2 ZynMixer driver
11 Korg nanoKONTROL
11.1 ZynMixer driver
12 Korg nanoKONTROL-2
12.1 ZynMixer driver
12.1.1 Common buttons
  • Track Left: UI Left arrow
  • Track Right: UI RIGHT arrow
  • Marker Left: UI UP arrow
  • Marker Right: UI DOWN arrow
12.1.2 NORMAL mode
    • Knob: Chain's balance
    • M: Chain's mute switch
    • S: Chain's solo switch
12.1.3 SHIFT mode
  • Strip 8: Main mixer control
    • Slider: Main volume
    • M: Main mute switch
    • R: Main recorder arm switch
13 Mackie Control
