Zynthian UI User Guide - V5
Revision as of 13:50, 3 November 2023 by Jofemodo (talk | contribs) (→‎Mixer)
  • adjusting parameters
  • the big 5x4 silicone button grid, that adds 20 push buttons with RGB LED feedback, allowing huge improvements in usability.
  • as a consequence, the 4 knobs are often used in quite a different way.
2 Using the push buttons
2.1 Screen access buttons
  • OPT/ADMIN
    • Admin menu
  • MIX/LEVEL
    • Mixer
  • CTRL/PRESET
    • Chain Control (Instrument)
    • Preset/Bank
  • ZS3/SNAPSHOT
    • SubSnapShots (ZS3s)
  • METRONOME
    • Tempo screen / Tap-Tempo
  • PAD/STEP
    • Scene (ZynPad)
    • Pattern
2.2 ALT button
2.3 Transport buttons
Pattern editor screen
Audio-player chain
2.4 Navigation buttons
  • Up/Down arrow buttons:
    • Browsing lists and menus.
  • Left/Right arrow buttons:
  • Select/Yes button:
  • Back/No button:
3 Using the knobs
3.1 General rule
  • Knob#1 - #4
3.3 Mixer
3.4 Scene (ZynPad)
    • short-push to MIDI learn the current pad by pushing a note in your MIDI controller.
3.5 Pattern
4 Workflow
4.1 Basics
4.2 Sequencer
4.3 Mini-HowTos
5 Work In Progress
