Zynthian FAQ
9 Despite I have a good PSU, a good SD card and a RBPi4, my Zynthian hangs
Maybe you have let the VNC server running while playing. Forwarding the sound engines native gui over the network is resource consuming. You should consider disabling the VNC server.
13 About Zynthian Security
FYI, everything in Zynthian is executed as root user.
- Secure the MOD-UI server:
