Zynthian UI User Guide - V1/V4
Revision as of 20:58, 23 July 2024 by Jofemodo (talk | contribs) (→‎Step Sequencer - ZynSeq)
  • Adjusting parameters
  • Bold-Back: Mixer
  • Long-Layer: Step Sequencer
  • Long-Back: Admin Menu
  • Long-Learn: All Notes Off
  • Long-Select: Power Off
1.1 The Title Bar
1.2 The Status Area
1.2.1 The Peak Meter
2.1 Chains
2.3 Navigation
3 The UI Screens
3.1 Mixer
3.1.1 Audio Chains
3.1.2 MIDI Chains
3.1.3 Contextual Actions
3.2 Main Menu
  • Snapshots manage snapshots
3.3 Engine Selector
3.4 MIDI Channel selector
3.5 Bank selector
3.6 Preset selector
3.7 Control View
3.8 Chain Options
3.9 Note Range & Transpose
3.10 XY-Controller
3.11 Load / Save Snapshot
  • Delete removes the snapshot
3.11.1 Snapshot Banks
3.11.2 Default Snapshot
3.11.3 Restore Last State
3.12 MIDI-learning / binding
3.12.1 MIDI CC
To unlearn a MIDI CC binding:
3.12.5 Creating a SubSnapShot
  • Delete removes the ZS3
3.13.1 Overview
3.13.2 Recording
3.13.3 Playing
3.13.4 Deleting
3.14.1 Recording Audio
3.14.2 Playback Audio
2. Select "Audio File Player"
3.14.3 General Usage
  • rename recordings
  • delete recordings
3.15 Audio Levels
3.16 Step Sequencer - Zynseq
3.16.1 Zynseq Views
Pads
Create and edit patterns.
3.17 Admin Menu
4 Touch Screen UI
5 CUIA: Callable UI Actions
Interface->UI Key Binding
0x9F  (Channel 16 Note ON)
0x00  (Velocity / parameter)
