Zynthian Webconf debug with Visual Studio Code (VSC)
Revision as of 09:21, 24 September 2025 by Jawn (talk | contribs) (→‎Visual Studio Code Configure.)
1 Debugging Webconf with Visual Studio Code
This is presented as an example of how Visual Studio Code (VSC) can be used to examine a component of the Zynthian sub system as it runs using the Visual Studio Code extensions: Python & Remote-SSH. These are loaded using the cog dialog at the bottom of the Visual Studio Code page.
Once you have these components added you can attempt to log onto an existing Zynthian from your PC, MAC, or Linux machine, just so long as it's capable of running Visual Studio Code. In my own case I have it running on a 64-bit Raspbian instance and I had to build it from source to get it running which is a degree of proof of the overall flexibility of what is after all, a Microsoft product!
Zynthian git graph
2 The ssh connection
To configure SSH connection to the Zynthian:
  • Click on the green icon at the bottom left of VSC (tooltip: Open a Remote Window) or F1 then type "Connect to host"
  • Select "Connect to host..."
  • Select "+ Add New SSH Host..."
  • Enter "ssh root@zynthian.local" (use the hostname or IP address of your Zynthian)
  • Select "/home/<username>/.ssh/config" to store this configuration in your ssh file (may differ on non *nix systems)
To connect to Zynthian:
  • Select the entry for the previously configured host, e.g. "zynthian.local"
  • Enter password
I already have a couple of remote Zynthians in the machine and VSC is pretty tenacious at hanging onto remote instances it knows about. But we will try to add a new machine.
I have a Zynthian called zynthian-orig.local. It's actually a genuine Zynthian product running a Pi3 and no membrane switches and some fairly simplistic interface. Indeed it has to be disassembled to change the ssd. Such were the early days.!
The fact that one can run this debug against the modern code is a sign of great overall consistancy.
Zynthian-orig.local
3 Visual Studio Code Configure.
First we need to add the extensions.
To access this we press on the + button against the appropriate machine. Visual Studio Code keeps and manages accurate records on the ssh connections you have made. It's handling of details down to the passwords and such and it's overall willingness to just do stuff as you would expect.
The -A option...?
-A Enable forwarding of the authentication agent connection.
We enter the details for our specific zynthian machine. Zynthian runs as root (atm). It always has done so make sure you put root in here. Many hours can be blissfully wile'd away wondering why you can see a machine you've logged into as the wrong user.
Once VSC has established a connection, it will download the appropriate python components to the zynthian to allow debugging to take place remotely. This make take some time and also may complain about missing components, give it some time it will get here if it possibly can....
4 Selecting the home directory on the Remote server
5 Running the Debugger
Once you have a specific module in focus you can run the debugger within that module. In this case zynthian_webconf.py ( The module that runs the webconf implementation). We are going to watch MIDI signals being acknowledged in the webconf display.
Make sure you have the python debugger extension loaded. This is done via the Cog in the lower left corner and selecting Extensions. Search on Python in the dialog and you should see a similar list to that below. It's a Microsoft component so it's efficacy is established. Select nd it will load it's self, It's pretty good at doing this but do give it some time to complete...
Selecting Run from Top meu will offer a set of options including debug. Press on this, and you will be offered a selection of options as below that allow choice of various environments in the python world that you may wish to be involved with. Select the top option.
6 Turning off Running Webconf instance
We run the debugger,
Error!!
but there is already a process running that has grabbed the port 80. It's the zynthian-webconf instance that is started by the raspberry pi when it starts up by systemd and this will need to be stopped to allow us to run our own instance....
So we use the terminal to generate a command line prompt and shout at systemd to turn of the running instance
systemctl stop zynthian-webconf
And look it's no longer running!!!
7 Running the debugger in anger ...
So leaving with the zynthian-webconf.py module highlighted start the debugger as before.
And then go and open the lib/midi_log_handler.py page once the web server is running and highlight the line 132 by pressing to the left of the line number a red circle should appear. . .
Then select the midi log page within webconf and play some midi . . . .
The program will halt on the debug line 132, and you should be able to operate the debugger transport controls and all the nice debug tools that will display and set values. The following shows it after step over has been pressed twice. . .
