ZynSeq User Guide
Revision as of 04:12, 7 July 2025 by Lfo (talk | contribs) (→‎Pattern Editor: Add note about accessing patterns)
Zynpad view
Event
Pattern
Track
Sequence
Group
Bar
Beat
Step
2.1 Pad Layout
3 Pattern Editor
4 Note Parameters
5 Scales and Drum Maps
  • Chromatic (piano keyboard)
  • Major
  • Minor
  • Blues
  • Blues pentatonic
Input Type Description
Loop Mode and Overdub
7 Playing a sequence
8 Multiple Sequences
9 Groups
10 Grid Size
11 Sequence Modes
Sequence play modes
Icon Mode Description
Disabled
One-shot
Loop
One-shot all
Loop all
One-shot sync
Loop sync
12 Sequence Names
13 Tempo
14 MIDI channels
15 Scenes
16 Save / Load / Snapshot
17 External Trigger
Feedback tallies
State MIDI velocity
Stopped 3
Starting 5
Playing 1
Stopping 4
18 Arranger
The Arranger is accessed from the menu. Bold press SELECT in ZynPad will also open arranger if the sequence is already configured with more than one track or pattern or the first pattern is not at start of sequence. Arranger shows each track as a row with its patterns shown as black boxes (with their pattern number in white) on a time line. Tracks are grouped within their sequence. This should be familiar to users of Digital Audio Workstations (DAW). The left hand column shows the sequence and track titles. The information shown is as follows:
18.2 The Arranger View
19 Time Signature
20 Metronome
21 Pattern Management
22 Import / Export MIDI Files
22.1 Export
22.2 Import
23 Timebase
25 Example Workflows
25.1 Live looping pads
25.2 Oneshot phrases
25.3 Linear song
25.5 Synchronisation
