ZynSeq User Guide
Event
Pattern
Track
Sequence
Group
Bar
A Bar is a musical entity. Each bar is an amount of time, with a recognised rhythm of beats Defined by Beats per Bar
Beat
Step
2.1 Pad Layout
3 Pattern Editor
4 Note Parameters
5 Scales and Drum Maps
- Chromatic (piano keyboard)
- Major
- Minor
- Blues
- Blues pentatonic
Input Type | Description |
Loop Mode and Overdub
7 Playing a sequence
8 Multiple Sequences
9 Groups
10 Grid Size
11 Sequence Modes
Icon | Mode | Description |
12 Sequence Names
13 Tempo
14 MIDI channels
15 Scenes
16 Save / Load / Snapshot
17 External Trigger
State | MIDI velocity |
Stopped | 3 |
Starting | 5 |
Playing | 1 |
Stopping | 4 |
18 Arranger
- Sequence name, e.g. A1
- Track number, e.g. 1
19 Time Signature
20 Metronome
21 Pattern Management
22 Import / Export MIDI Files
22.1 Export
22.2 Import
23 Timebase
25 Example Workflows
25.1 Live looping pads
25.2 Oneshot phrases
25.3 Linear song
25.5 Synchronisation
