ZynSeq User Guide
Revision as of 17:07, 2 October 2024 by Riban (talk | contribs) (Remove menu section - this is detailed in main user guide)
Event
Pattern
Track
Sequence
Group
2.1 Pad Layout
3 Pattern Editor
4 Note Duration
5 Note Velocity
6 Scales and Drum Maps
  • Chromatic (piano keyboard)
  • Major
  • Minor
  • Blues
  • Blues pentatonic
Input Type Description
Loop Mode and Overdub
8 Playing a sequence
9 Multiple Sequences
10 Groups
11 Grid Size
12 Sequence Modes
Sequence play modes
Icon Mode Description
Disabled
One-shot
Loop
One-shot all
Loop all
One-shot sync
Loop sync
13 Sequence Names
14 Tempo
15 MIDI channels
16 Scenes
17 Save / Load / Snapshot
18 External Trigger
Feedback tallies
State MIDI velocity
Stopped 3
Starting 5
Playing 1
Stopping 4
19 Arranger
Arranger showing default
  • Sequence name, e.g. A1
  • Track number, e.g. 1
19.2 Navigating Arranger View
20 Time Signature
21 Metronome
22 Pattern Management
23 Import / Export MIDI Files
23.1 Export
23.2 Import
24 Timebase
25 User Interface Settings for Touchscreen/Headless Setups
25.1 Controlling the Interface With a Qwerty Keyboard or MIDI Device with CUIA: Callable UI Actions
26 Example Workflows
26.1 Live looping pads
26.2 Oneshot phrases
26.3 Linear song
26.5 Synchronisation
