Contributing to Zynthian Development backup
1 So what is an IDE ?
VSC Download Page
Pi Desktop Download Folder
Pi Desktop VSC menu item
Zynthian home directory
Zynthian-ui directory
1.4 What happens if zynthian crashes and how do I stop it restarting on errors ?
systemctl stop zynthian
systemctl start zynthian
systemtl status zynthian
X -r -s 0
2 How do I Debug a Zynthian?
2.1 Explorer
2.2 Search
2.3 Source Control
2.4 Run & Debug
2.5 Extensions
2.6 Remote Explorer
2.7 Testing
2.8 Accounts
Microsofts domain control
2.9 Manage
Admin Tasks
   "version": "0.2.0",
   "configurations": [
           "name": "Zynthian",
           "type": "debugpy",
           "request": "launch",
           "justMyCode": true,
           "env": {
               "DISPLAY": ":0"
           "name": "Zynthian Debug",
           "type": "debugpy",
           "justMyCode": true,
           "subProcess": true,
           "env": {
               "DISPLAY": ":0",
               "ZYNTHIAN_LOG_LEVEL": "10"
type: X -r -s 0
Zynthian page at Github
So we better write some code.
3 It is 'suggested' one creates a task/issue? how do I do that ?
So to repeat,
3.1 So what have we gained here ?
Zynthian page at GitHub
and press the . key...
on your host machine type:
4.3 How Do I redirect the zynthian code in zynthian-ui to my personnal repository rather than the zynthian master I forked from ?
cd .git
if you now type
ls -las
cat config
[core]
       repositoryformatversion = 0
       filemode = true
       bare = false
       logallrefupdates = true
[remote "origin"]
[branch "master"]
       remote = origin
       merge = refs/heads/master
[branch "testing"]
       remote = origin
       merge = refs/heads/testing
[branch "staging-2209"]
       remote = origin
[branch "stable"]
       remote = origin
       merge = refs/heads/stable
[branch "staging-2307"]
       remote = origin
[branch "chain_manager"]
       remote = origin
We want to change the line
nano config
4.4 How Do I Start a new branch and what should I call it ?
4.7 Can I see a diagram of the various branches in the zynthian github page ?
5 So what is LV2?
5.1 From wikipedia...
LV2 (LADSPA Version 2) is a set of royalty-free open standards[2] for music production plug-ins and matching host applications. It includes support for the synthesis and processing of digital audio and CV,[3] events such as MIDI and OSC, and provides a free alternative to audio plug-in standards such as Virtual Studio Technology (VST) and Audio Units (AU).
LV2 is an interface for writing audio plugins in C or compatible languages, which can be dynamically loaded into many host applications. This core specification is simple and minimal, but is designed so that extensions can be defined to add more advanced features, making it possible to implement nearly any feature.
LV2 maintains a strong distinction between code and data. Plugin code is in a shared library, while data is in a companion data file written in Turtle. Code, data, and any other resources (such as waveforms) are shipped together in a bundle directory. The code contains only the executable portions of the plugin. All other data is provided in the data file(s). This makes plugin data flexible and extensible, and allows the host to do everything but run the plugin without loading or executing any code. Among other advantages, this makes hosts more robust (broken plugins can't crash a host during discovery) and allows generic tools written in any language to work with LV2 data. The LV2 specification itself is distributed in a similar way.
LV2 is an extensible framework, allowing a program to load a plugin to do some processing. Note that the terms used here are generic on purpose because LV2 allows any type of data to be exchanged between the host and the plugin.
5.3 In Summary
So there is a clear distinction between the definitions of the facilities which are held in carefully defined definition files and the actual software that accesses the facilities by reading the definition files. This way there is a controlled interaction betwenn the host and the plugin and each can be protected from the vagueries of the other.
It is a list of definitions that refer back to core definitions and these relationships are maintained in a format called RDF . . .
5.4 So what is RDF ?
Once more from wikipedia...
The Resource Description Framework (RDF) is a method to describe and exchange graph data. It was originally designed as a data model for metadata by the World Wide Web Consortium (W3C). It provides a variety of syntax notations and formats, of which the most widely used is Turtle (Terse RDF Triple Language).
It describes objects and the relationships between them . . .
RDF represents information using semantic triples, which comprise a subject, predicate, and object. Each item in the triple is expressed as a Web URI. Turtle provides a way to group three URIs to make a triple, and provides ways to abbreviate such information, for example by factoring out common portions of URIs. For example, information about Huckleberry Finn could be expressed as:
<http://example.org/books/Huckleberry_Finn>
  <http://example.org/relation/author>
  <http://example.org/person/Mark_Twain> .
In the zynthian plug in world it's primarily about the definition, allocation and mapping of audio and midi ports and parameters in the zynthian world to parameters provided by the LV2 plugin we are exchanging data with.
@prefix lv2:  <http://lv2plug.in/ns/lv2core#>.
@prefix doap: <http://usefulinc.com/ns/doap#>.
@prefix spdx: <http://spdx.org/rdf/terms#>.
Then you use these prefixes to define the relationships we are concerned with...
The 'a' is an atom. More news as I get it. . .
<http://example.org/lv2/wikipediaexample/silence>
 a lv2:Plugin;
 lv2:binary <silence.so>;
 doap:name "Silence";
 doap:license spdx:GPL-3.0-or-later;
 rdfs:comment "This is an example plugin that includes an example plugin description."
 lv2:port [
   a lv2:AudioPort, lv2:OutputPort;
   lv2:index 0;
   lv2:symbol "output";
   lv2:name "Output";
Not sure.
5.4.1.2.1 libasound2-dev
Alsa Lib asound2 . . .
5.4.1.2.2 lv2-dev
5.4.1.3 Anything else?
There are:
  1. Juce
  2. DPF
5.4.1.4 Juce
Juce has a huge number of components relating to pretty well anything you need - GUI, audio processing, networking, etc. - and is particularly popular amongst audio software developers. You can find a lot more     information and some snappy demos on the Juce site.
It turns out that Juce supports the Raspberry Pi "out of the box" as long as you install a few libraries before you start. I created a sample application on the Mac, copied it to a Raspberry Pi and compiled it,  and it worked right the first time!
5.4.1.5 DPF
DPF is designed to make development of new plugins an easy and enjoyable task.
It allows developers to create plugins with custom UIs using a simple C++ API.
The framework facilitates exporting various different plugin formats from the same code-base.
 DPF can build for LADSPA, DSSI, LV2, VST2, VST3 and CLAP formats.
 A JACK/Standalone mode is also available, allowing you to quickly test plugins.
Then make a directory.
mkdir SimpleGainPlugin
cd SimpleGainPlugin
5.4.1.6 So which is better?
6 LV2 Components
6.1 A Notch Filter
6.1.1 The Definition Files
6.1.2 The Code components
6.1.2.1 DisthroPluginInfo.h
#define DISTRHO_PLUGIN_BRAND "Wyleu"
#define DISTRHO_PLUGIN_URI "http://zynthian.org/plugins/lv2/simplegain"
#endif
#endif
6.1.2.3 DisthroPluginMain.cpp
#include "DistrhoPlugin.hpp"
START_NAMESPACE_DPF
class SimpleGainPlugin : public Plugin {
public:
   SimpleGainPlugin() : Plugin(1, 0, 0) { // 1 parameter, 0 programs, 0 states
protected:
       if (index != 0) return;
       parameter.name = "Gain";
       parameter.symbol = "gain";
       parameter.unit = "x";
       parameter.ranges.def = 1.0f;
       parameter.ranges.min = 0.0f;
       parameter.ranges.max = 2.0f;
       if (index != 0) return 0.0f;
       return gain;
       gain = value;
       const float* inL = inputs[0];
       const float* inR = inputs[1];
       float* outL = outputs[0];
       float* outR = outputs[1];
           outL[i] = inL[i] * gain;
           outR[i] = inR[i] * gain;
private:
   float gain;
Plugin* createPlugin() {
END_NAMESPACE_DPF
It includes the header files
we define a class:
public:
So what's the rest of it...
Two sections
  1. protected:
  2. private:
6.1.2.4.1 Protected:
getDescription()
getMaker()
getLicense()
       return gain;
       gain = value;
an array of inputs
an array of outputs
A frame count. The number of frames in the array.
and then do stuff
6.1.2.4.2 Private:
6.1.2.5 makefile
#!/usr/bin/make -f
NAME=SimpleGain
DPF_PATH=../../DPF
TARGETS=lv2
all: $(TARGETS)
6.1.2.6 makefile what does it do ?
wyleu@raspberrypi:~/Code/lv2/DPF/SimpleGainPlugin $ make -n
mkdir -p /bin/SimpleGain.lv2
echo "Creating LV2 plugin for SimpleGain"
g++ /build/SimpleGain/DistrhoPluginMain_LV2.cpp.o -Wall -Wextra -pipe -MD -MP -fno-gnu- unique -fPIC -DPIC -DNDEBUG -O3 -ffast-math -fdata-sections -ffunction-sections - fvisibility=hidden -DHAVE_ALSA -DHAVE_JACK -DHAVE_RTAUDIO  -DHAVE_X11  -DHAVE_XEXT - DHAVE_XSYNC -DHAVE_OPENGL -std=gnu++11 -fvisibility-inlines-hidden -I. -I../../DPF/distrho - I../../DPF/dgl -I../../DPF/dgl/src/pugl-upstream/include -fdata-sections -ffunction-sections  -Wl,-O1,--as-needed,--gc-sections -Wl,--strip-all  -Wl,--no-undefined -ldl     -shared -Wl,-- version-script=../../DPF/utils/symbols/lv2.version -o /bin/SimpleGain.lv2/SimpleGain.so
Live child 0x555658e367a0 (/bin/SimpleGain.lv2/SimpleGain.so) PID 51392
Reaping winning child 0x555658e367a0 PID 51392
Live child 0x555658e367a0 (/bin/SimpleGain.lv2/SimpleGain.so) PID 51393
Reaping winning child 0x555658e367a0 PID 51393
Live child 0x555658e367a0 (/bin/SimpleGain.lv2/SimpleGain.so) PID 51394
/usr/bin/ld: cannot open output file /bin/SimpleGain.lv2/SimpleGain.so: Permission denied
6.2 Auto Leveller
A Place holder for information on the construction of this component and a casual implementation of some kind of document structure.
Auto Leveller
AutoLeveller GUI
6.2.1 What is it?
You can think of it as your angry sound engineer in a live situation, both during soundcheck and during the gig. Initially it will turn your output volume down to a reasonable level. It will also do that if anything unforseen happens in the chain (you add another plugin which features an integer gain multiplier and is set to gain=20). When set the right values (try the preset “Tuned”) it should level any source to a loudness level somewhere into yellow meter territory.
It also features two programs:
6.2.2 Parameters
6.2.2.1 Pre Gain (dBfs)
Adjust the pre amplification in case you deal with quieter sources (like soundfonts) you want to boost before getting into the automatic levelling.
6.2.2.2 Theshold Peak (dBfs)
Set your maximum peak levels you want to have. Setting the threshold will reset your former gain reduction so it can listen from the start again. When “Listen” is on, it will only turn the volume downwards. Recommended values are between 0 and -4 dBfs.
6.2.2.3 Theshold RMS (dBfs)
Set your maximum RMS levels you want to have. Setting the threshold will reset your former gain reduction so it can listen from the start again. When “Listen” is on, it will only turn the volume downwards. The detector is estimating RMS values of a 300ms window by a using a lowpass filter. Recommended values are between -14 and -18 dBfs.
6.2.2.4 Listen (bool)
When engaged (by default) it will perform detection and level matching. When disengaged it will keep the current gain, but will not further listen. If engaged again, the gain reduction will be reset.
If not edited further, LV2 parameters will be presented in a manner being sorted by their parameter ID and grouped in groups of four without helpful group names. We can edit a specific file to get some more helpful named and ordered parameter groups. It is highly recommended to study other custom control ttl files before edit your own one.
7.1 Location
On any zynthian update database regeneration zynthian will replace the original ttl file with the ones in /zynthian/zynthian-data/lv2-custom.
7.2 Editing the ttl file
7.2.1 Namespace prefixes
Most of the time we have to add some lines to the header, if not already present:
@prefix rdf:  <http://www.w3.org/1999/02/22-rdf-syntax-ns#> .
@prefix pg:   <http://lv2plug.in/ns/ext/port-groups#> .
@prefix plug: <COPY URN FROM PLUGIN BLOCK> .
7.2.2 Control groups
Add control groups like that outside the plugin block, for example right at the end of the file. Groups with higher displayPriority values will be displayed on top of your parameter group view. GROUP1 and the symbol "group1" can be named yourself (only letters, numbers or _", name "Group1 Display Name" you can also edited and will show on your UI.
plug:GROUP1
   a pg:ControlGroup ;
   lv2:name "Group1 Display Name" ;
   lv2:symbol "group1" ;
   lv2:displayPriority 3 .
plug:GROUP2
   a pg:ControlGroup ;
   lv2:name "Group2 Display Name" ;
   lv2:symbol "group2" ;
   lv2:displayPriority 2 .
7.2.3 Parameter assignment
Add following lines to every control port representing a parameter (contains "a lv2:ControlPort", so not the audio input and output ports), while display priority goes from higher to lower numbers as well:
pg:group plug:GROUP1 ;
lv2:displayPriority 1 ;
7.2.4 Scale Points
This is especially helpful for integer or boolean like enumeration parameters and other parameters which should have stepped controls. Here we have an example for a boolean parameter, which should only be in state "On" or "Off":
lv2:scalePoint [
   rdf:value 0.0 ;
   rdfs:label "OFF" ;
   rdfs:comment "OFF" ;
   rdf:value 1.0 ;
   rdfs:label "ON" ;
   rdfs:comment "ON" ;
It has to be like that because typically (oftentimes, but not necessarily) parameters are represented as floating point values (0.000f to 1.000f), even if they're supposed to be boolean or integer, even if LV2 would support these kind of data. Other parameters could be of "integer logic". Let's assume the parameter "Waveform" would have the states "Saw, Sine, Square, Triange", we may assume that every floating point value from 0.0f to <0.25f represents "Saw" and so on. Then we might try this (while value and label are mandatory, comment is not):
lv2:scalePoint [
   rdf:value 0.0 ;
   rdfs:label "Saw" ;
   rdfs:comment "Saw" ;
   rdf:value 0.25 ;
   rdfs:label "Sine" ;
   rdfs:comment "Sine" ;
   rdf:value 0.5 ;
   rdfs:label "Square" ;
   rdfs:comment "Square" ;
   rdf:value 0.75 ;
   rdfs:label "Triangle" ;
   rdfs:comment "Triangle" ;
Sometimes we have parameters which have no function and must not be displayed. You add the following line to the parameter definition:
lv2:portProperty pp:notOnGUI ;
So a single parameter should for example look like this:
       a lv2:InputPort, lv2:ControlPort ;
       lv2:index 8 ;
       lv2:symbol "delaytimesync" ;
       lv2:name "Host Sync" ;
       lv2:default 0.473684 ;
       lv2:minimum 0.0 ;
       lv2:maximum 1.0 ;
       pg:group plug:DELAY ;
       lv2:displayPriority 2 ;
       lv2:scalePoint [
           rdf:value 0.0 ;
           rdfs:label "Free" ;
           rdfs:comment "Free" ;
           rdf:value 0.052631 ;
           rdfs:label "1/16" ;
           rdfs:comment "1/16" ;
           rdf:value 0.105263 ;
           rdfs:label "1/8" ;
           rdfs:comment "1/8" ;
           rdf:value 0.157895 ;
           rdfs:label "1/4" ;
           rdfs:comment "1/4" ;
           rdf:value 0.211053 ;
           rdfs:label "1/2" ;
           rdfs:comment "1/2" ;
           rdf:value 0.263158 ;
           rdfs:label "1/1" ;
           rdfs:comment "1/1" ;
           rdf:value 0.315789 ;
           rdfs:label "2/1" ;
           rdfs:comment "2/1" ;
           rdf:value 0.368421 ;
           rdfs:label "1/16." ;
           rdfs:comment "1/16." ;
           rdf:value 0.421052 ;
           rdfs:label "1/8." ;
           rdfs:comment "1/8." ;
           rdf:value 0.473684 ;
           rdfs:label "1/4." ;
           rdfs:comment "1/4." ;
           rdf:value 0.526316 ;
           rdfs:label "1/2." ;
           rdfs:comment "1/2." ;
           rdf:value 0.578947 ;
           rdfs:label "1/1." ;
           rdfs:comment "1/1." ;
           rdf:value 0.631579 ;
           rdfs:label "2/1." ;
           rdfs:comment "2/1." ;
           rdf:value 0.684211 ;
           rdfs:label "1/16T" ;
           rdfs:comment "1/16T" ;
           rdf:value 0.736842 ;
           rdfs:label "1/8T" ;
           rdfs:comment "1/8T" ;
           rdf:value 0.789474 ;
           rdfs:label "1/4T" ;
           rdfs:comment "1/4T" ;
           rdf:value 0.842105 ;
           rdfs:label "1/2T" ;
           rdfs:comment "1/2T" ;
           rdf:value 0.894736 ;
           rdfs:label "1/1T" ;
           rdfs:comment "1/1T" ;
           rdf:value 0.947368 ;
           rdfs:label "2/1T" ;
           rdfs:comment "2/1T" ;
           rdf:value 1.0 ;
           rdfs:label "-" ;
           rdfs:comment "-" ;
The bold line is the one we started to insert things. You typically should only edit the "name" value, which is the display label and the newly added values. In this case we added the control to the previously added group named "DELAY", added the displayPriority, so that it will be displayed within the group above all parameters with value <2 and below paramters with value >2. Then we added stepped controls for delay times defined by subdivisions of the host tempo, where the values represent 1/19, 2/19, 3/19... Continuous parameters typically do not need scale points at all, rather they would become stepped parameters as well if we'd add them.
7.3 Recommended workflow
Instead of just copying the ttl over to the respective directory and edit it for your own use you can make things easier for the devs to implement your custom feature and share it with everybody this way:
  • Fork the zynthian/zynthian-data repositories vangelis branch
  • Checkout to that branch in your zynthian
  • Develop using your fork
  • Make a pull request
