Zynthian UI User Guide (oldstable-2109)
- Bold-Back: Main Menu
 - Long-Layer: Step Sequencer
 - Long-Back: Admin Menu
 - Long-Learn: Audio Levels
 - Long-Select: Power Off
2 The Title Bar
3 The Status Area
| Status Icons Legend | ||
| m | MIDI-IN | It's shown when MIDI messages are received. |
| XRun | It's shown when there are Xruns. If many, you should hear clicks and pops too. This means the CPU can't process audio fast enough and you should consider disabling some CPU-hungry option (like VNC, headphones, etc.) or reducing the complexity of your layer setup. | |
| Recording Audio/MIDI | An audio or MIDI recording is going on. | |
| Playing Audio/MIDI | An audio or MIDI track is being played. | |
3.1 The Peak-meter
4 The Zynthian UI Workflow
5 The UI Screens
5.1 Main
- Layers
 - Sequencer
 - Clean All
5.2 Layers
- from any place, bold-layer
 - from Main menu
- Presets
 - Replace
 - Move Upchain
 - Move Downchain
 - Remove
5.3 Engine Selector
5.4 MIDI Channel selector
5.5 Bank selector
5.6 Preset selector
5.7 Control screen
5.7.1 XY-Controller
5.8 Load/Save Snapshot
5.8.1 Snapshot Banks
5.8.2 Default Snapshot
5.8.3 Restore Last State
5.9 MIDI-learning
Please bear in mind that in the case of USB connected MIDI devices the learnt settings will apply only to the specific USB Configuration in place at the time of learning. So if you add a USB hub to the rig the ZS3 sub-snapshots won't act.
5.9.1 MIDI CC
Every ZS3 includes:
5.10 Audio & MIDI Recording
5.10.1 Overview
5.10.2 Recording
5.10.3 Playing
5.10.4 Deleting
- rename recordings
 - delete recordings
5.11 Audio Levels
5.12 Step Sequencer
These are three main views:
Pads
5.13 Admin Menu
The resistive touchscreen works better with a stylus. Finger is too coarse. It's strongly recommended to run the calibration using a stylus.
6 Touch Screen UI
Learning:
Unlearning:
7 CUIA: Callable UI Actions
| Action | Modifier | Key |
| ALL_OFF | Ctrl | Space |
| BACK_DOWN | CapsLock | Down |
| BACK_UP | CapsLock | Up |
| LAYER_DOWN | Shift | Down |
| LAYER_UP | Shift | Up |
| POWER_OFF | Ctrl | End |
| REBOOT | Ctrl | Home |
| RESTART_UI | Shift | Home |
| SELECT_DOWN | None | Down |
| SELECT_UP | None | Up |
| SNAPSHOT_DOWN | Ctrl | Down |
| SNAPSHOT_UP | Ctrl | Up |
| SWITCH_BACK_BOLD | Shift | BackSpace, Escape, Left |
| SWITCH_BACK_LONG | Ctrl | BackSpace, Escape, Left |
| SWITCH_BACK_SHORT | None | BackSpace, Escape, Left |
| SWITCH_LAYER_BOLD | Shift | l |
| SWITCH_LAYER_LONG | Ctrl | l |
| SWITCH_LAYER_SHORT | None | l |
| SWITCH_SELECT_BOLD | Shift | Return, Right |
| SWITCH_SELECT_LONG | Ctrl | Return, Right |
| SWITCH_SELECT_SHORT | None | Return, Right |
| SWITCH_SNAPSHOT_BOLD | Shift | s |
| SWITCH_SNAPSHOT_LONG | Ctrl | s |
| SWITCH_SNAPSHOT_SHORT | None | s |
| TOGGLE_AUDIO_PLAY | CapsLock+Shift | a |
| TOGGLE_AUDIO_RECORD | CapsLock | a |
| TOGGLE_MIDI_PLAY | CapsLock+Shift | m |
| TOGGLE_MIDI_RECORD | CapsLock | m |
100 LAYER_CONTROL E7
