Building a Zynthian Box using an official Kits v4.2, v4.3 & v4.4
Introduction
Zynthian Shop
Specifically, these instructions are for assembling the Zynthian Kit v4.2, that includes the Hifiberry DAC+ADC Stage with the ZynAuCon connector board, the Zynaptik circuit and the ZynScreen v1.5 display.
List of Materials
Some definitions
Zynthian
Zynthian Software
+ GNU Linux Operating System: RaspberryPi OS Buster (Debian Buster)
+ Jack Audio Daemon
What is Free Software?
It's a compressed image file (plenty of soundfonts) compiled for Raspberry Pi 3 and Raspberry Pi 4. The SD-card images include all the Zynthian software, properly configured for working with the official kits. Completely ready to use. Plug and play!
If you don't know how to do it, you can use Raspberry Pi Imager or Etcher (free software, works on Mac, Windows or Linux) to flash the image onto the micro-SD card. Or do it manually! There is a really good manual for this at this link.
Zynthian Box
In the project's repositories you can find all the electric schemes, PCB specifications, Gerber files, etc. to build your own Zynthian Box from scratch:
- Zynthian Case Repository
Zynthian Kit v4
A Zynthian Kit is a set of electronic and mechanic parts. The official Zynthian Kit v4.2 consists of these parts:
+ 1 x Raspberry Pi 4
+ 1 x Hifiberry DAC+ADC PRO
+ 1 x ZynAuCon Module + Mini-ribbon cable
+ 1 x ZynScreen v1.5: Touch-Display 3.5" + Controllers circuit + Silicone buttons
+ 1 x Ribbon bus cable
+ 1 x Zynthian Aluminium Case
+ 1 x MIDI Connectors Set + LEDs
+ 1 x Bolts & Nuts Set
+ 1 x Zynductor
Rbpi4 shop.jpgHifiBerryDACADC-Stage-top.jpgIMG 2775 OK shop.JPGControllers shop.jpegZynaptik shop.jpegRibbon shop.jpegZynthian alucase v41-persp.jpgZynAuCon miniribbon.jpgIMG 2887 OK 1024.JPGBoltsnuts.JPGIMG 2756 OK shop.JPG
Unboxing the Zynthian Kit v4
Unboxing the Official Kit V4, by Richard Nevill
Assembling your Zynthian Box
Prerequisites
Please, handle electronic parts with care, specially the display, as they are easily damaged. Touch grounded metal before starting, e.g. a radiator or desk lamp to discharge static electricity and avoid wearing synthetic fibre clothing, e.g. polyester shirt.
Let's go!!
Secure the ZynAuCon Audio Connector Board
The ZynAuCon module improves and simplifies the audio wiring by using a small ribbon cable for driving the 4 balanced channels (2 inputs + 2 outputs) to the 4 high-quality Neutrik TSR case-connectors. For mounting the ZynAuCon, secure the 2 x 15mm separators with 2 x black-anodized bolts M2.5. Next, you have to insert the board from inside the case and secure them with the 4 x nuts from the outside. Use a wrench for tightening the nuts, but not too much, and take care of not damaging the surface of the nice aluminum case!!
Secure the MIDI connectors
Mount the MIDI activity LEDS
Insert the 3 LEDS in the case from the outside, with the short lead on the left looking from within the case. Make sure you push the LEDs by the plastic collar around the LED, not the LED itself. This may require some force due to the friction fit of the LED within the hole. This may be assisted with a small tube with internal diameter of approximately 3mm, e.g. 3-4mm socket spanner or the narrow end of the plastic body of a ball point pen (with its stylus removed).
* JST Green wire (1) => LED's long lead (Anode)
* JST Yellow wire (2) => LED's short lead (LED's Cathode)
Since the LED's leads are too long, you will want to cut them down to about 7-8mm. Make sure you remember which lead is the short one. (You could mark the inside of the case with pencil as a reminder.) When inserting the DuPont connector, if you feel that it doesn't grab the pins enough, you should press the tiny metal-jacket inside the plastic capsule to make it narrow. It's easy, simply put the DuPont connector over the desk and press the metal with the screwdriver tip or something like that.
If wish to omit the status LEDs you must short JP1 & JP2 jumpers on the Zynaptik board otherwise the MIDI-OUT and MIDI-THRU won’t work.
Prepare the Zynductor Passive Cooler
1. Cut the thermal tape in 2 pieces. One of 4cm long and the second one of 2cm long.
2. Remove the protective yellow paper from the long piece and stick the tape carefully on the zynductor, taking care of covering the long area that contacts the aluminum case. Use a cutter to remove the excess.
3. Repeat the procedure with the short piece and the square area that contacts tha RBPi's CPU.
Secure the Main Computing Block and assemble the Zynductor Passive Cooler
Although you are able to swap and change SD cards on your completed Zynthian, if you already have an SD card with the latest stable image ready to go, you can save yourself some fiddling about later by inserting it into the Pi now.
The main computing block consists of the Raspberry Pi and the HifiBerry soundcard,and is assembled using separators and bolts. The Zynductor passive cooler is a little piece of aluminum that sticks to the RBPi's CPU and the aluminum case, creating a thermal channel for evacuating the heat generated by the RBPi's CPU. For getting the best performance, you have to follow carefully these steps:
1. Fix the 2x4 separators to the Raspberry Pi. Put the longest of the two on top of the Pi and the shorter at the bottom.
2. Secure the Raspberry Pi to the bottom of the aluminum case using 4 tiny black bolts M2.5
 3. Remove the blue protective covers from both the zynductor's contact area.
 4. Stick the zynductor over the RBPi's CPU, taking special care of assuring the contact between the aluminum case and the zynductor's long contact area.
 5. Plug-in the HifiBerry soundcard on to the Raspberry Pi.
 6. Fix the 4 screws on top of the HifiBerry to fix it in place.
Note that the "Hifiberry DAC+ADC Stage", included in the 4.1, 4.2 & 4.3 kits, and the "ZynADAC", included in the 4.4 kit, have no RCA connectors. Photos may show an older model, but these instructions are accurate for 4.1 to 4.4 kits.
Secure the Zynaptik module
Mount the Display
Mount the Controllers
Attach the knobs
Attach the rubber feet
Connecting everything
Connect the Ribbon Bus cable
Connect the Controllers
Connect the MIDI connectors & activity LEDs
Connect the ZynAuCon module to the Hifiberry DAC+ADC Stage
Plug the little 2x10 ribbon cable on the Hifiberry's J1 connector. Next, plug the other end on the ZynAuCon board. Observe that the ribbon cable must be bent forming a 90º angle, so it fits perfectly the space and distance between the 2 IDC connectors.
FYI, this is the specification for the 10-pin header (J1) on the Hifiberry DAC+ADC Stage:
Connect the Display
Connect the ribbon's 26-pin connector to the display's connector. Pay attention to the orientation. The red wire should be on pin 1, as marked on the display's PCB surface. You MUST remove the red-jumper that is plugged in the connector, indicating the pin 1 position too.
Please, double-check this step carefully because you could break the display if it's connected wrongly!!
Testing your Zynthian Box
Double-check the parts and wiring
First Boot
1. Insert the SD-card with the zynthian image. If you don't have one yet, read this. You can insert the SD-card through the "window" on the bottom-side of the case. The SD-card is inserted with the (gold) pins facing the top of the case and the manufacturer's print facing the bottom of the case.
Test the Controllers & UI
Test the Audio Output
Test the MIDI subsystem
Test the MIDI-USB inputs
Test the MIDI-IN connector
Final steps
Close the case
Be careful not to over-tighten the case screws, as it can buckle the top plate. If you notice the top place bowing slightly, loosen the screws a little until the surface is level.
Update your Zynthian Box
Locating and Solving problems
The display don't show the zynthian splash screen on boot
You get the zynthian error screen with the IP
Your controllers doesn't work
You can't solve the problem
Technical Reference
Error creating thumbnail: convert-im6.q16: unrecognized color `none;' @ warning/color.c/GetColorCompliance/1052. convert-im6.q16: non-conforming drawing primitive definition `fill' @ error/draw.c/RenderMVGContent/4301.
ZynScreen v15 sch.svg
