Zynthian UI User's Guide - Oram
Topbar back button
Title Short press Show menu
Title Bold press ZynPad view
Title Long press Admin menu
Global MIDI input/output view is accessed from the admin menu. It allows to manage MIDI input/output sources and modify MIDI device global options:
  • enable/disable bluetooth devices
  • rename the device
Chain's MIDI input/output view is accessed from the chain's options menu. It allows to select the devices from which it will receive MIDI input or to which it will send MIDI output.
In addition. you can also modify global device options:
  • load/unload drivers
  • rename the device
  • Access Main Menu.
  • The easy way
  • The cool way
10 Learning Pills
10.1 Basics
10.2 Sequencer
10.3 Mini-HowTos
