Zynthian Mini kit is a cost effective approach to build zynthian with intention to give opportunity:
- to zynthian developers to get functional zynthian similar to v5 where they can do most of the testing
- to musician to get to know zynthian and learn their features before deciding to buy the professional kit
- include encoders and switches that controll zynthian software in the same way as official zynthian v5 kit using the MCP23017 i/o extender
- include MIDI IN, MIDI OUT and MIDI THRU
- include a I2S DAC for AUDIO OUT based on PMC5102 chip that is affordable to buy
- does not need any cabling inside for easy assembling
- does not need the case to test it but it include design of two type of enclosure
- simple enclosure that only cover the top and bottom part of the device that can be also produced in the same way as PCBs
- full enclosure that can be 3d printed
- all connectors are easy to reach (V1 does not have RPI connectors aligned to the edge of the PCB)
To save the cost of building the Zynthian MINI, we had to sacrifice certain features that some professional musicians would need on the stage such as:
- no audio-in
- no TRS audio connectors
- not best in the class DAC for audio out
- no rigid metal case
- no zynaptik analog inputs
Zynthian is currently at version 2. Previous version 1 was more similar to official V4 kit with only 4 buttons but it is not maintained anymore.
To assemble zynthian mini V2 version you will require:
- PCB that need to be produced based on KiCad design that you can find in zynthian hardware repository.
- Components that need to be soldered to this PCB.
- 5" Screen
- Raspberry Pi 4 with heatsink
- optional: zynthian MINI V2 3d printable case
1 Assembling the PCB
1.1 Components required
- Value: 470u 10V
- PCB label: C1
- Package: CP_Radial_D8.0mm_P3.50mm
- Quantity: 1
- Where to buy: https://www.aliexpress.com/item/1005003189675117.html
- Value: 100u
- PCB label: C4
- Package: CP_Radial_D6.3mm_P2.50mm
- Quantity: 1
- Value: 100n
- PCB label: C2,C3,C5,C6,C7
- Package: C_Rect_L7.0mm_W2.0mm_P5.00mm
- Quantity: 5
- Where to buy: https://www.aliexpress.com/item/1005005894912292.html
- Value: 100n
- PCB label: C22,C16,C19,C13,C23,C20,C9,C26,C27,C32,C8,C18,C21,C34,C33,C17,C25,C11,C24,C31,C12,C15,C10,C14
- Package: C_Rect_L4.0mm_W2.5mm_P2.50mm
- Quantity: 24
- Where to buy: https://www.aliexpress.com/item/1005002290441861.htm
- Value: 10n
- PCB label: C30,C29,C35,C37,C38,C28,C39,C36
- Quantity: 8
5. Diode
- Value: 1N4148
- PCB label: D1
- Package: D_DO-35_SOD27_P7.62mm_Horizontal
- Quantity: 1
- Where to buy: https://www.aliexpress.com/item/32660088529.html
- PCB label: MIDI-OUT-J1, MIDI-IN-J1, MIDI-THRU-J1
- Package: MultiDIN5
- Quantity: 3
- Where to buy: https://www.aliexpress.com/item/1005005773478404.html
7. Resistors
- Value: 220R
- PCB label: R1,R3,R5,R4,R6
- Package: R_Axial_DIN0207_L6.3mm_D2.5mm_P7.62mm_Horizontal
- Quantity: 5
- Where to buy: https://www.aliexpress.com/item/1005005669886834.html
8. Resistor
- Value: 1k
- PCB label: R2
- Quantity: 1
9. Resistor
- Value: 10k
- PCB label: R8,R7
- Quantity: 2
10. Digital Optocoupler
- Value: H11L1M
- PCB label: U2
- Package: DIP-6_W7.62mm
- Quantity: 1
- Where to buy: https://www.aliexpress.com/item/32867427644.html
- Value: 74HCT14
- PCB label: U1
- Package: DIP-14_W7.62mm
- Quantity: 1
- Where to buy: https://www.aliexpress.com/item/33020259485.html
12. Sound Card PCM5102
- Value: GY-PCM5102
- PCB label: A1
- Package: GY-PCM5102
- Quantity: 1
- Where to buy: https://www.aliexpress.com/item/1005002898278583.html
13. I/O Expander
- Value: MCP23017_SP
- PCB label: MCPMCP23017_SP1, MCPMCP23017_SP2
- Package: DIP-28_W7.62mm
- Quantity: 2
- Where to buy: https://www.aliexpress.com/item/1005005363863079.html
- Male:
- PCB label: HAT1
- Package: PinSocket_2x20_P2.54mm_Vertical
- Quantity: 1
- Where to buy: https://www.aliexpress.com/item/4000133266617.html
- Female:
- PCB label: RPi1
- Package: two spacer female 40pin vertical header
- Quantity: 1
- Where to buy: https://www.aliexpress.com/item/4001095693537.html
15. Encoder with a Switch
- Value:
- PCB label: Enc2,Enc4,Enc1,Enc3
- Package: RotaryEncoder_Alps_EC12E-Switch_Vertical_H20mm
- Quantity: 4
- Where to buy: https://www.aliexpress.com/item/1005006142236380.html
16. Encoder Cap
- Value: encoder caps
- PCB label: Encoder caps
- Package: Encoder caps
- Quantity: 4
- Where to buy: https://www.aliexpress.com/item/1005005835327286.html
17. Push Button
- Value:
- PCB label:SW14,SW9,SW16,SW20,SW6,SW10,SW8,SW2,SW17,SW4,SW12,SW19,SW5,SW1,SW13,SW18,SW15,SW7,SW11,SW3
- Package: push-button
- Quantity: 20
- Where to buy: https://www.aliexpress.com/item/32912263133.html
- Value: Screen
- PCB label: RPI 5" screen
- Package: RPI screen
- Quantity: 1
- Where to buy: https://www.aliexpress.com/item/1005005353135304.html
- Where to buy heatsink: https://www.aliexpress.com/item/1005004774833369.html
20. 1/4 Stereo jack
- Value: J1
- PCB label: J1
- Package: Jack_6.35mm_Neutrik_NMJ6HFD2_Horizontal
- Quantity: 1
- Where to buy: https://www.aliexpress.com/item/4001266094691.html
21. RCA Stereo jack
- Value: J2
- PCB label: J2
- Package: RCA RS-234
- Quantity: 1
- Where to buy: https://www.aliexpress.com/item/1005001629197904.html
1.2 Soldering
Then solder the switches.
1.3 Assembling the PCB for the test
2 Configure Zynthian MINI V2 for testing
2.1 Connect to zynthian web UI to update zynthian software
- touching the top corner of the screen
- selecting admin option
- selecting wifi enable option
- selecting your network
- entering your wifi password
2.2 Update zynthian oram software
2.3 Configuring zynthian mini v2 as a kit
2.4 Adjusting UI for Zynthian layout
3 Assembling Zynthian MINI V2 into 3d printable enclosure
- This is most important part because it encloses all internal parts together. You can print just this part and have zynthian mini much more secured then just standing on stand offs.
- Bottom part closes the bottom of the case and comes with opening for the SD Card.
- SD card door
- This is a SD card door that is attached to bottom part for easy access to zynthian's raspberry pi SD Card.
- Legs
- These are small legs that are attached (glued) to the bottom part. They are designed to be a separate part from bottom part so that bottom part can be placed to printing bed and sliced without too much additional support. There is one stl file for one leg so you will need to print four of these.
You can either print this case yourself if you have a printer or give these 4 files to some of your friends that have it and point them to instructions here. Also you can request somebody to print this for you on thingiverse.
3.1 3D printing instructions
- importing them to printer's slicing software
- make copy of leg part so taht there are four of them
- lay the top side of top.stl part onto the printer bed
- lay the top side of sd-card-door.stl part onto the printer bed
- leave legs as they are imported
- arrange all part nicely aso that they do not overlap (you can use slicers auto arange feature)
- set "zynthian mini" logo with "no support" instructions - there is not need to add support to these letters (it depend on the slicer how you do that but typically you can do this by painting them with no support indicator)
- slice it with 15% infill and with support
- do you standard preparation of you printer before prinitng (e.g. bed level, z offset etc)
- upload the print instructions from slicer and start printing
[https://youtu.be/5RSKHbG7Gxg Here} is a timelapse of the print.
Then print bottom part. Lay bottom side of bottom part onto the printer bed. Use the same settings as for previous parts. Bottom part will be printed much quicker.
3.2 Assembling all parts into 3D printed case
1. Case Top part 2. Case Bottom part 3. Case SD Card door part 4. Case legs parts 5. brass heat set inserts (quantity 8) - M2.5xL4xOD3.5 - can be purchased here 6. screws for brass heat set inserts (quanity 8) - M2.5, 6mm - can be purchased here 7. 5" DSI screen and its screws - can be purchased here 8. zynthian MINI V2 PCB - check instructions above how to assemble it 9. enncoder caps (quantity 4) and nuts - check PCB components required above where to buy it 10. Neutrik 1/4 stereo connector cap - can be purchased [1] 11. raspberry pi 4 with heatsink 12. raspbery pi posts and their screws
- their size depend on heatsink - the standard zynthian MINI V2 PCB build recommends two spacers connector which is 16mm long so that there is enough space for raspberry pi to cool - therefore if heatsink is 7mm then raspberry pi posts need to be 9mm (7mm+9mm=16mm)
13. HAT posts (quantity 4) - 11mm standard. 14. Tools required - soldering iron for inserting heat set inserts and small phillips screw driver
3.3 Insert 3 heat set inserts into top and 5 into bottom part
3.4 Put screen inside the top part
3.5 Screw raspberry pi posts and HAT posts to the PCB
3.6 Put PCB into the case and attach the screen screws
3.7 Screw PCB to the case
3.8 Screw encoder screw nuts
3.9 Screw Neutrik connector nut
3.10 Attach screen cable to the raspberry pi
3.11 Connect raspberry pi to the PCB
