ZynSeq User Guide
Revision as of 04:58, 20 June 2025 by Riban (talk | contribs) (Update MIDI clock info)
Event
Pattern
Track
Sequence
Group
Bar
A Bar is a musical entity. Each bar is an amount of time, with a recognised rhythm of beats Defined by Beats per Bar
Beat
Step
2.1 Pad Layout
3 Pattern Editor
4 Note Parameters
5 Scales and Drum Maps
  • Chromatic (piano keyboard)
  • Major
  • Minor
  • Blues
  • Blues pentatonic
Input Type Description
Loop Mode and Overdub
7 Playing a sequence
8 Multiple Sequences
9 Groups
10 Grid Size
11 Sequence Modes
Sequence play modes
Icon Mode Description
One-shot Sequence will play once, i.e. not loop. When stopped sequence will stop immediately (this is the only mode that will stop immediately)
One-shot all Sequence will play once, i.e. not loop. When stopped sequence will continue to play until end of sequence
Loop all Sequence will loop at end of sequence. If sequence ends before sync point it will pause and restart at next sync point (end of bar). When stopped sequence will continue to play until end of sequence. This is the default mode.
One-shot sync Sequence will play once, i.e. not loop. When stopped sequence will continue to play until next sync point (end of bar)
12 Sequence Names
13 Tempo
14 MIDI channels
15 Scenes
16 Save / Load / Snapshot
17 External Trigger
Feedback tallies
State MIDI velocity
Stopped 3
Starting 5
Playing 1
Stopping 4
18 Arranger
  • Sequence name, e.g. A1
  • Track number, e.g. 1
18.2 Navigating Arranger View
19 Time Signature
20 Metronome
21 Pattern Management
22 Import / Export MIDI Files
22.1 Export
22.2 Import
23 Timebase
25 Example Workflows
25.1 Live looping pads
25.2 Oneshot phrases
25.3 Linear song
25.5 Synchronisation
