ZynSeq User Guide
Event
Pattern
Track
Sequence
Group
2.1 Pad Layout
3 Pattern Editor
4 Note Parameters
5 Scales and Drum Maps
  • Chromatic (piano keyboard)
  • Major
  • Minor
  • Blues
  • Blues pentatonic
Input Type Description
Loop Mode and Overdub
7 Playing a sequence
8 Multiple Sequences
9 Groups
10 Grid Size
11 Sequence Modes
Sequence play modes
Icon Mode Description
Disabled
One-shot
Loop
One-shot all
Loop all
One-shot sync
Loop sync
12 Sequence Names
13 Tempo
14 MIDI channels
15 Scenes
16 Save / Load / Snapshot
17 External Trigger
Feedback tallies
State MIDI velocity
Stopped 3
Starting 5
Playing 1
Stopping 4
18 Arranger
Arranger showing default
  • Sequence name, e.g. A1
  • Track number, e.g. 1
18.2 Navigating Arranger View
19 Time Signature
20 Metronome
21 Pattern Management
22 Import / Export MIDI Files
22.1 Export
22.2 Import
23 Timebase
25 Example Workflows
25.1 Live looping pads
25.2 Oneshot phrases
25.3 Linear song
25.5 Synchronisation
