LV2 plugins
Zynthian supports almost 600 LV2 plugins. Recent discussion is here: https://discourse.zynthian.org/t/beta-tests-more-lv2-plugins-for-mod-ui/656/46
Incomplete List of LV2 Plugins supported by Zynthian
  • 3BandEQ
  • 3BandSplitter
  • AmplitudeImposer - Takes 2 stereo inputs and imposes the amplitude envelope of the first one on the second one.
  • CycleShifter - Reads in a cycle's-worth of the input signal, then outputs it again, on top of the current output.
  • Dexed - synth that is closely modeled on the Yamaha DX7 https://asb2m10.github.io/dexed/
  • EasySSP - audio visualization tool, which currently provides spectrometer and goniometer views
  • JuceDemoHost
  • JuceDemoPlugin
  • Kars -Simple karplus-strong plucked string synth.
  • KlangFalter - convolution audio plugin, e.g. for usage as convolution reverb https://github.com/HiFi-LoFi/KlangFalter* LUFSMeter
  • LUFSMeterMulti - The LUFS Meter plugin measures loudness similar to the human perception of loudness.
  • Luftikus - analog EQ with fixed half-octave bands and additional high frequency boost https://www.kvraudio.com/product/luftikus-by-lkjb
  • MVerb - Studio quality, open-source reverb
  • MaBitcrush - from https://docs.cycling74.com/max7/vignettes/gen_topic
  • MaFreeverb
  • MaGigaverb
  • MaPitchshift
  • Nekobi - single-oscillator synth based on the Roland TB-303
  • Obxd - Oberheim OB-X synth https://www.kvraudio.com/product/ob-xd---virtual-analog-synthesizer-by-discodsp
  • PingPongPan
  • SoulForce - A fairly standard waveshaping distortion plugin, made more interesting through the use of feedback to control the shaping.
  • StereoSourceSeparation
  • TAL-Dub-3 - vintage style delay effect https://www.kvraudio.com/product/tal-dub-iii-by-togu-audio-line
  • TAL-Filter-2- host-synced filter module with different filter types, panorama and volume modulation https://www.kvraudio.com/product/tal-filter-ii-by-togu-audio-line
  • TAL-Filter
  • TAL-NoiseMaker-Noise4U
  • TAL-NoiseMaker - synth engine includes a small effect section https://www.kvraudio.com/product/tal-noisemaker-by-togu-audio-line
  • TAL-Reverb-3 - stereo plate https://www.kvraudio.com/product/tal-reverb-iii-by-togu-audio-line
  • TAL-Reverb
  • TAL-Vocoder-2
  • TheFunction -manipulate a stereo signal giving complete control over the output https://www.kvraudio.com/product/the-function-by-arctican-audio
  • ThePilgrim -high-pass and low-pass filter programmed into one dial, and allows a seamless sweep between the two. It works similar to the 'Pioneer DJM' mixers https://www.kvraudio.com/product/the-pilgrim-by-arctican-audio
  • Vex -Vex is a 3 oscillator subtractive wavesample synth http://www.linuxsynths.com/VexPatchesDemos/vex.html
  • Wolpertinger - subtractive, antialiased polyphonic software synthesizer http://tumbetoene.tuxfamily.org/
  • ZynAddSubFX
  • ZynAddSubFX
  • ZynAlienWah
  • ZynChorus
  • ZynDistortion
  • ZynDynamicFilter
  • ZynEcho
  • ZynPhaser
  • ZynReverb
  • a_law-swh
  • alias-swh
  • allpass-swh
  • am_pitchshift-swh
  • amp-swh
  • analogue_osc-swh
  • avw
  • bandpass_a_iir-swh
  • bandpass_iir-swh
  • bode_shifter-swh
  • bode_shifter_cv-swh
  • butterworth-swh
  • calf
  • chebstortion-swh
  • comb-swh
  • comb_splitter-swh
  • const-swh
  • crossover_dist-swh
  • dc_remove-swh
  • decay-swh
  • decimator-swh
  • declip-swh
  • delay-swh
  • delayorama-swh
  • diode-swh
  • divider-swh
  • dj_eq-swh
  • dj_flanger-swh
  • drowaudio-distortion
  • drowaudio-distortionshaper
  • drowaudio-flanger
  • drowaudio-reverb
  • drowaudio-tremolo
  • drumkv1
  • drumsynth
  • dyson_compress-swh
  • eqinox
  • fad_delay-swh
  • fast_lookahead_limiter-swh
  • flanger-swh
  • fm_osc-swh
  • foldover-swh
  • fomp
  • foverdrive-swh
  • freq_tracker-swh
  • gate-swh
  • giant_flange-swh
  • glBars - OpenGL bars visualization plugin (as seen in XMMS and XBMC/Kodi)
  • gong-swh
  • gong_beater-swh
  • gverb-swh
  • hard_limiter-swh
  • harmonic_gen-swh
  • hermes_filter-swh
  • highpass_iir-swh
  • hilbert-swh
  • impulse-swh
  • inv-swh
  • karaoke-swh
  • latency-swh
  • lcr_delay-swh
  • linuxsampler
  • lookahead_limiter-swh
  • lookahead_limiter_const-swh
  • lowpass_iir-swh
  • ls_filter-swh
  • matrix_ms_st-swh
  • matrix_spatialiser-swh
  • matrix_st_ms-swh
  • mbeq-swh
  • mda
  • mod_delay-swh
  • multivoice_chorus-swh
  • phasers-swh
  • pitch_scale-swh
  • plate-swh
  • pointer_cast-swh
  • rate_shifter-swh
  • retro_flange-swh
  • revdelay-swh
  • ringmod-swh
  • samplv1
  • satan_maximiser-swh
  • sc1-swh
  • sc2-swh
  • sc3-swh
  • sc4-swh
  • se4-swh
  • shaper-swh
  • sifter-swh
  • simple_comb-swh
  • sin_cos-swh
  • single_para-swh
  • sinus_wavewrapper-swh
  • smooth_decimate-swh
  • split-swh
  • surround_encoder-swh
  • svf-swh
  • synthv1
  • tape_delay-swh
  • transient-swh
  • triple_para-swh
  • u_law-swh
  • valve-swh
  • valve_rect-swh
  • vocoder
  • vynil-swh
  • wave_terrain-swh
  • xfade-swh
  • zm1-swh
  • carla - audio plugin host supports LADSPA (including LRDF), DSSI, LV2, VST2/3 and AU plugin formats, plus GIG, SF2 and SFZ file support http://kxstudio.linuxaudio.org/Applications:Carla
