Building a Zynthian Box using an official Kit v4.0
Zynthian Shop
Specifically, these instructions are for assembling the Zynthian Kit v4.0. that includes the Hifiberry DAC+ADC PRO with the Zynaptik circuit and the ZynScreen v1.5 display.
If you have a newer kit 4.X with X>0, you should choose the right tutorial for your kit!
2 List of Materials
3 Some definitions
3.1 Zynthian
3.2 Zynthian Software
+ GNU Linux Operating System: RaspberryPi OS Buster (Debian Buster)
+ Jack Audio Daemon
What is Free Software?
It's a compressed image file (plenty of soundfonts) compiled for Raspberry Pi 3. The SD-card images include all the Zynthian software, properly configured for working with the official kits. Completely ready to use. Plug and play!
3.3 Zynthian Box
- Zynthian Case Repository
3.4 Zynthian Kit v4
A Zynthian Kit is a set of electronic and mechanic parts. The official Zynthian Kit v4 consists of these parts:
+ 1 x Raspberry Pi 4
+ 1 x Hifiberry DAC+ADC PRO
+ 1 x ZynScreen v1.5: Touch-Display 3.5" + Controllers circuit + Silicone buttons
+ 1 x Ribbon bus cable
+ 1 x Zynthian Aluminium Case
+ 1 x Connectors Set
+ 1 x Bolts & Nuts Set
+ 1 x Zynductor
Rbpi4 shop.jpgHifiberry-dacplusadcpro.jpgIMG 2775 OK shop.JPGControllers shop.jpegZynaptik shop.jpegRibbon shop.jpegIMG 2744 OK shop.JPGIMG 2765 OK shop.JPGBoltsnuts.JPGIMG 2756 OK shop.JPG
Unboxing the Official Kit V4, by Richard Nevill
4.1 Prerequisites
Let's go!!
4.2 Secure the unbalanced audio output jack-TS connectors
These 2 connectors are pre-assembled together and share a single harness with 3 wires ended with a 3-pin dupont connector.
Insert the jack connectors into the 2 holes labeled as audio OUT. You have to insert them from inside the case and secure them with the washers and nuts from the outside. The washers will keep the nut from damaging the case. Use a wrench for tightening the nuts, but not too much!!
4.3 Secure the balanced audio input jack-TRS connectors
These are 2 separated connectors with a 3-wire harness each, ended with 3 x 1-pin dupont connectors.
Insert the jack connectors into the 2 holes labeled as audio IN. You have to insert them from inside the box and secure them with the washers and nuts from the outside. The washers will keep the nut from damaging the case. Use a wrench for tightening the nuts, but not too much!
4.4 Secure the MIDI connectors
4.5 Mount the MIDI activity LEDS
Since the LED's leads are too long, you will want to cut them down to about 7-8mm. Make sure you remember which lead is the short one. When inserting the dupont connector, if you feel that it doesn't grab the pins enough, you should press the tiny metal-jacket inside the plastic capsule to make it narrow. It's easy, simply put the dupont connector over the desk and press the metal with the screwdriver tip or something like that.
4.6 Prepare the Zynductor Passive Cooler
1. Cut the thermal tape in 2 pieces. One of 4cm long and the second one of 2cm long.
2. Remove the protective yellow paper from the long piece and stick the tape carefully on the zynductor, taking care of covering the long area that contacts the aluminum case. Use a cutter to remove the excess.
3. Repeat the procedure with the short piece and the square area that contacts tha RBPi's CPU.
4.7 Secure the Main Computing Block and assemble the Zynductor Passive Cooler
The main computing block consists of the Raspberry Pi and the HifiBerry soundcard,and is assembled using separators and bolts. The Zynductor passive cooler is a little piece of aluminum that sticks to the RBPi's CPU and the aluminum case, creating a thermal channel for evacuating the heat generated by the RBPi's CPU. For getting the best performance, you have to put all your attention and follow carefully these steps:
1. Fix the 2x4 separators to the Raspberry Pi. Put the longest of the two on top of the Pi and the shorter at the bottom.
2. Secure the Raspberry Pi to the bottom of the aluminum case using 4 tiny black bolts M2.5
 3. Remove the blue protective cover from the zynductor's square contact area, the one that contacts the RBPI's CPU. Don't remove the other one yet!!
 4. Stick the zynductor over the RBPi's CPU, taking special care of assuring the contact between the aluminum case and the zynductor's long contact area, the one with the blue protective cover still there.
 5. Remove the RBPi from the case, untightening the tiny black blots.
 6. Plug-in the HifiBerry soundcard on to the Raspberry Pi.
 7. Fix the 4 screws on top of the HifiBerry to fix it in place.
 8. Remove the blue protective cover from the zynductor's long contact area, the one that contacts the aluminum case.
 9. Finally, fix the main computing block to the case, using the 4 remaining tiny black bolts M2.5 to secure it to the bottom of the case.
4.8 Secure the Zynaptik module
4.9 Mount the Display
4.10 Mount the Controllers
4.11 Attach the knobs
4.12 Attach the rubber feet
5 Connecting everything
5.2 Connect the Controllers
5.5.1 HifiBerry DAC+ADC PRO
Connect the 2 x balanced input jack connectors to the audio-input header on the sound card using the 3x1 pin Dupont connectors as indicated in the image:
I recommend you take a look at Hifiberry DAC+ADC PRO specification.
5.6 Connect the Display
Connect the ribbon's 26-pin connector to the display's connector. Pay attention to the orientation. The red wire should be the pin 1, which as marked on the display's PCB surface. Probably you need to remove the red-jumper that is plugged in the connectors pins 1-2, indicating the right position.
Please, double check this step carefully because you could break the display if it's connected reversed!!
6 Testing your Zynthian Box
6.2 First Boot
6.3 Test the Controllers & UI
6.4 Test the Audio Output
6.5 Test the MIDI subsystem
6.6 Test the MIDI-USB inputs
7 Final steps
7.1 Close the case
8 Update your Zynthian Box
10 Technical Reference
Error creating thumbnail: convert-im6.q16: unrecognized color `none;' @ warning/color.c/GetColorCompliance/1057. convert-im6.q16: non-conforming drawing primitive definition `fill' @ error/draw.c/RenderMVGContent/4404.
File:ZynScreen v1.3.svg
