Beginners Headless Zynthian Tutorial
A headless Zynthian is a Raspberry Pi with ZynthianOS without the screen, the buttons and the knobs. Here's a simple as possible step by step beginners tutorial to setup a headless Zynthian.
Zynthian can be controlled remotely via another computer, a tablet, a smartphone or a midi controller. In most of the cases, the Zynthian Kit is the better way to use ZynthianOS. However, if you want to try Zynthian before you purchase a Zynthian Kit or experiment with another type of configuration, a headless setup allows this.
2 Hardware
  1. Raspberry Pi (Pi4 recommended)
  2. SD card (class 10)
  3. Power supply (take the official one)
  4. (optionnal but recommended for the best audo experience) an I2S DAC (sound card) (recommended sound cards)
3 ZynthianOS
  1. Download the last stable Zynthian OS image
  2. Download Etcher
  3. Burn the ZynthianOS image on an SD card
4 Network Connection
  • The more simple way for making a network connexion is to directly connect an ethernet cable from the Raspberry Pi to the computer.
  • Another way is to connect the two devices to an Ethernet switch.
5 Web Browser
You will need a web browser but not all are working well for that purpose.
  • Google Chrome is reported to works well
6 First Boot
  1. Put the SD on the raspberry
  2. Power on by plugin the power supply
  3. Wait a little bit
  4. Open your web browser
password = raspberry
There are tools available to activate the bonjour mechanism to allow using the name which is a much more flexible option.
If you cannot enter to the Zynthian WebConf Tools, wait a little bit more. Then try to reboot by powering off. Then, try to burn another SD card.
7 Configure Internet
  • If you are connected via an ethernet switch, connect the switch to your internet box
  • If you are directly connected via an ethernet cable, configure the Wifi on the WebConf page:
System / WIFI / Add Network
Mode = ON
8 Update ZynthianOS
Now that you are connected to the Internet, you can update Zynthian OS via the WebConf:
Software / Update
System / Reboot
9 Configure the hardware
Configure your hardware setup via the WebConf:
Hardware / Kit / Custom
Hardware / Audio / Select your soundcard on the list or choose RBPiHeadphones
Hardware / Display / Generic HDMI Display
Hardware / Wiring / DUMMIES
System/sys-reboot / Reboot
10 Activate VNC Server on the Raspberry Pi
VNC allows you to remotely have the Raspberry Pi screen on your personal computer, your tablet or your smartphone. With your browser pointing to http://zynthian.local, navigate to Interface => UI Options scroll at the bottom and check "Enable VNC server"
11 Install VNC Viewer in your Devices
1. Download and install VNC viewer in your devices:
2. Connect to the Zynthian UI via VNC: You should be on the same network (ethernet cable and/or Wifi). Type the raspberry pi IP address (on Windows and android) or zynthian.local (on MacOS and iOS) in VNC Viewer.
User name : root
Password : raspberry
You should now have the Zynthian UI working remotely.
For a better use, configure Zynthian UI for headless use in the WebConf:
Interface / UI options
Advanced view : ON
Enable Touch Widgets: ON
Enable cursor: ON
On stage, you can disconnect the Zynthian from internet and configure it as a hotspot for connecting your devices to it. For this, go to the WebConf:
System / WIFI / Hotspot
12 OPTIONAL STEPS
12.1 Controlling Headless Zynthian With A Computer Keyboard or MIDI Device
While a touch interface allows control for a headless Zynthian setup, adding a computer keyboard or MIDI keyboard or controller (such as a NanoKontrol) will allow a greater range of controls at your fingertips.
See CUIA: Callable UI Actions for info about keyboard shortcuts and MIDI controls.
12.2 Accessing the Native GUI
If you want to access from your computer to the Graphical User Interface of softwares like Pure data or Pianoteq that run on the Raspberry Pi, you need to install an X11 server on your computer:
On the X11 server’s terminal (xterm) that run on your computer, send the command:
ssh -Y root@zynthian.local
On the Zythian UI, create a new Pure Data layer (or other engine with supported native GUI) and the Pure Data GUI should appears on your computer screen.
  • Note that you can access MOD-UI (the virtual pedal board) without X11. When you have created a MOD-UI layer, just go to the WebConf :
Software / MOD-UI
12.3 Accessing the ZynthianOS Folders
If you want to graphically access to the Zynthian OS files and folders (not recommended for beginners):
1. install an SFPT client on your computer:
2. Open an SFPT connection:
Server : zynthian.local (MacOS) or IP Address (Windows)
User : root
3. If, for exemple, you want to access to the Pure Data externals folders for manually installing externals that aren’t available via another way, simply use it as a normal finder and go to:
/usr/lib/pd/extra
And upload your custom externals.
